Hi folks,
I love the separate black and grey water on the tab 320, but when I am at a site with water and sewer I figure I should just hook the grey water up to drain continuously. What is the best way to do this?
I have an aftermarket grey tank line cap that lets me hook up a hose, but would you just snake that into the drain? Seems a bit gross but maybe not and maybe I just need to devote a bag to the hose I use for this?
1 ·
It's not normally allowed to leave the hose dangling in the open drain, unless you devised some sort of sealing fitting for the drain that would fit your garden hose. I've owned such a device with a system called "Sewer Solution" that can drain both black and grey tanks through a small hose, works very well. No large slinky needed.
Doug
Minnesota and Arizona
I let my gray water tank fill up (or close to it) so that I can use the gray water to flush out my sewer hose each time I drain the black tank. When you need to drain the black tank, always do that first, followed by the gray water tank. If you do not have hookups at a campground and need to dump your holding tanks at a dump station, it becomes even more helpful to have a fairly full gray water tank for the same reason - - - to have a good strong flow of gray water to flush out any black water tank residue that was left behind in your sewer hose after first draining the black water tank.
Even if you are not using the black water tank, it is still a good idea (in my view) to let the gray water tank fill up (or close to it) before dumping it as needed. I say that, because if you just leave it open all the time, you are more likely to have residue from washing dishes, etc., ending up in your constantly nearly dry holding tank, not to mention in the sewer hose (because neither get a good flushing.)
Again, just my opinion, but based on many years of RVing. Have fun!
P.S. Can you post the year model of your trailer? When you are camped at a private campground or other location that has sewer hookups at your site, you don't generally need a portable gray water tank (assuming that is what you referenced in the second part of your question.) You just hook your sewer hose (e.g., a Rhino or Valterra sewer hose) directly between your trailer's sewer drain and the campsite sewer drain. The portable gray water tank is generally for use when you do not have hookups (e.g., when boondocking or in a forest service campground), but occasionally need to drain your trailer gray water holding tank (or at least free up some holding capacity) and dump the portable tank at a nearby dump facility.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
But given what folks have said about leaving the sewer connections open that is a great point. I will just leave my house attached, but laying on the ground, and empty it when necessary.
I guess one of my main concerns was sticking the hose in the sewer line anyway since that has got to be pretty nasty. I guess I just won't do that! And be careful not to get too close
At least there is no smell here! Probably because we have only been putting greywater down it and leaving it closed.
As for those with black tanks, I think the odor from your own black tank vent is worse than the odor from the sewer drain. I don't think you can drain and rinse these too often.
Doug
