I couldn't find it anywhere in any of the documents I was given when I purchased my new 2022 TAB320S Boondock so here is the response I got from Nucamp when I asked them...I haven't seen where it is located yet as I sadly had to cover it for the winter before even using it
Thanks for reaching out to us. First off, congratulations on your purchase and welcome to the nuCamp family! Yes, all of the 2022 units will have an inline pressure regulator installed from the factory. I hope this helps and if you have any other questions please reach out.
Have a great day!
I find the nüCamp response confusing as they say "all of the 2022 units will have"
They did not say ' Your 2022 model year has'
So the response could mean ' all the 2022 build year units' which will mainly be 2023 model year.
@MuttonChops I agree that the language used in the email was ambiguous. I sent Nucamp a reply to clarify and will share here when they do.
@scott14 thank you for this. My camper is stored now but will look for it and the PSI in the spring when I take it out.
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
Yes, your 2022 should have one. I have provided a highlighted photo and it should be located behind the Nautilus panel on the inside of the unit.
The picture they sent me shows the same part as highlighted by @scott14
I will have to double check in the spring when I take it out of storage.
2022 T@b 320 S / 2021 Subaru Outback
Kevin
It was a short lived modification. I believe it was problematic and discontinued. Use an external one.
Relentlessly Pursuing a 2025 Silverado EV
Racing the Wind and Chasing the Sun
Virginia Beach, VA
Minnesota and Arizona
I also added some auto heater hose on the alde piping and the electrical conduit as they were vibrating on the plywood when the pump was running. much quieter now.
2025 Toyota Tundra / Nashville, TN
