I've read about EMS systems vs Surge protection, and I'm inclined to get a
Progressive Industries RV Surge Protector 30 Amp with Electrical Management System, Portable, EMS-PT30X.
My hesitation has more to do with the reliability of the unit, and the service and warrenty response. Does anyone have concrete experience with getting satisfactory response from Progressive service department? Thanks.
0 ·
It has several times alerted me of problems with the campground power post and disconnected us.
Highly recommended...
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
https://tab-rv.vanillacommunity.com/discussion/comment/171009/#Comment_171009
https://tab-rv.vanillacommunity.com/discussion/comment/86347#Comment_86347
https://tab-rv.vanillacommunity.com/discussion/11243/surge-protector/p1
https://tab-rv.vanillacommunity.com/discussion/12492/hardwiring-progressive-30-amp-ems-surge-protector
https://tab-rv.vanillacommunity.com/discussion/11078/hardwired-hughes-power-watchdog-in-2021-t-b-400/p1
https://tab-rv.vanillacommunity.com/discussion/13013/my-installation-of-the-ems-lchw30-in-a-2018-cs-s
https://tab-rv.vanillacommunity.com/discussion/13139/surge-protector-recommendation/p1
https://tab-rv.vanillacommunity.com/discussion/9183/hard-wiring-a-surge-protector-in-a-tab-400-help#latest(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase w/ Victron SmartSolar MPPT 75/15 Controller; Victron BMV-712 Battery Monitor w/ Shunt; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Both times I've installed my HW30C it was a simple matter of finding a convenient spot along the orange romex running from the outside receptacle to the power center. The length of the unit provides enough slack in the cut romex to easily connect it at each end. The remote display is simply a phone type data cable that is easy to route almost anywhere. Bayliss pictures look pretty similar to both my installations.
Adding that a new is being provided as Progressive technical team straight away were clear that their units should remain weather tight and once opened up to dry out (as I did) may never seal right again and water always leave debris. A photo of the inside with the rusty contractor connections which had been in the water.
Juliet and Andy in Massachusetts
