Hello, I have new 2023 TAB320 with factory Lithium. I had a fan issue (cover break) that got repaired under warranty today. After bringing RV home, I realized that I can't power anything with battery (batteries are fully charged). I had to believe the dealership turned something off as it worked perfectly before repair. They said they only changed fan and connected the 2 wires (they replaced entire Fan). When plugged into power everything works and all the stats on the Victron app look correct. Wondering if something easy I should check before I haul it back to the dealership. Fortunately, dealership is only 20 minutes from house but still a hassle. Thanks
0 ·
Definitely have battery switch on, it's inside next to the door. I'll check the other things that you both mention as well.
Good chance the Gloso Breaker was tripped / turned Off.
Breaker is under the Drivers side bench seat.
That situation would match your failure mode.
https://tab-rv.vanillacommunity.com/discussion/16047/reports-on-gloso-circuit-breakers-blowing
https://tab-rv.vanillacommunity.com/discussion/comment/185252#Comment_185252
If not a tripped/bad Gloso breaker (seems unlikely it is defective since it previously worked), or a blown fuse (including the 40A "reversed polarity" fuse, as already suggested by @ScottG), I would be looking for a disconnected wire, including a ground wire, close to the battery. A wire could have pulled out its wire connector.
If you delivered the trailer to the dealer with the battery installed and the disconnect switch "On," then it seems likely that they would have either disconnected the battery terminal cable(s) or at least turned "Off" the disconnect switch. Maybe call them and ask them to confirm with the person who did the repair that the ONLY wires they disconnected were at the fan itself and that they confirmed the fan worked on 12V after they replaced the fan. If so, ask why they would not have disconnected the 12V power before replacing the fan (at least for safety reasons, but also to avoid blowing a fuse.)
One other troubleshooting step might be to use a jumper wire to temporarily bypass the Gloso breaker to see if that gets you power. I can't see why you couldn't do that, but hopefully others will chime in if I am wrong about that.
Be sure to disconnect the 120V AC power before doing any troubleshooting of the 12V system.
My earlier comment (above) was incorrect, sorry.
But no harm in resetting the Gloso.
Another thing to try - - for data - - is to observe the Smart Dongle LED Lights.
How do they change with shore power off/on ?
I wonder if this AIMS power be tripped somehow? Not sure how to read it.
I have no direct experience with that style of fuse, picture does not look promising.
Do you have an ohmmeter so you can remove the fuse and test it for continuity?
The AIMS inline fuse being Open would explain the Shore Power OK but no Battery only power. However, if our wiring diagram estimate is correct that would not explain why the Smart Doogle has different LED Status when shore power is on/off.
Also, if AIMS inline fuse is Open - - - there was a very high current event. Which is puzzling as to when and why.
You should demand that your fan again be replaced with the identical or better fan. Not an earlier version. You deserve (under warranty) to receive what you originally paid for. Makes me wonder if the fan wiring is contributing to the problem. You may want to check the wiring there. Did the dealer say the fan worked after they replaced it? Did you test the fan before leaving the dealer?
Also, you indicated that the battery is fully charged. How have you confirmed that? Did you check it with a meter? (Since it is new, it should be good, but it would help for troubleshooting purposes if you can independently confirm a full charge........again, while disconnected from shore power.)
How do I know this is a 150 amp for replacement? I'm not that savvy with this stuff (hence the reason I bought the lithium package vesion vs DIY)
I do have an ohmmeter I believe so I may try to figure that out later to test.
I believe this is the AIMS fuse for 150 - Inline fuse 150 AMP Fuse - AimsPower (aimscorp.net)
Thanks for the comments.
Jericho, VT
