I got the 100 Watt Renogy Suitcase with 20a PWM controller to add to my roof mounted 190 watt panel with Victron
Mppt. It came with a battery clamp cord that isn't practical in a TAB 400 (Battery under bed). I cut the battery clamps off and wired the cord to a 7 pin socket. Works like a charm with no trailer wiring. I got 80 watts output with a slightly overcast day. Will only use the suitcase for shady campsites or to supplement roof panel on cloudy days.
2017 T@B 320 Outback 2023 400 BD (IdahoTabato) pushing a 2023 Volvo XC90
3 ·
relentlessly pursuing a
2025 Silverado EV
2018 T@B 320 Sold
Racing the Wind and Chasing the Sun
Virginia Beach, VA
The solar SAE port that the factory provides on the 2021 400 isn’t in the best spot to do this but the 7-pin would be perfect.
I know this may be obvious to some here but right now my mind can’t seem to figure out how to accomplish this.
2020 Tacoma TRD Off-Road
So it’s as easy as just wiring up the + and - of the 7-pin to a 12v (cig or SAE plug)?
Now I can just plug power into the trailer's 7-pin and run a fairly short run of wire back to my truck bed. I'll need to be mindful of water ingress but overall a much simpler solution and I have a spare 7-pin connector lying around here too.
