The radiant heat from the rear convectors builds up under the bed and is not very efficient. I bought a blower fan to increase the air flow. The plan is to mount it under the bed so that it forces air through the gap at the back. The question I have is about how to wire it?
One idea is to tap into the glycol circulation pump so that when the pump is on the fan will run. The down side to this is that at the beginning of the cycle the fan will be pushing cold air until the convectors heat up. At the end it will shut off while the there's still heat to be pushed out from under the bed.
Another option is to put it on a separate switch and activate it manually. I could use a thermostat under the bed, but want to keep it simple.
I'm looking for options for wiring. This is something that has probably already been done, but I haven't found it.
2022 Ford F350 Tremor | 2022 Cirrus 620
After more searching I did find a post with a similar mod.
Alde fan for convector fins
This is not a great picture, but you can see the dimmer in the upper right and the fan at the lower left. Bottom picture to show where wires are connected.
