I have a 2021 T@b 320S and live in the northeast. I have wintered it and it is now in storage. The storage unit is a garage with no room to move the T@b around. I jacked the front to get it level and put it on some blocks. Not sure if that was necessary but it made sense. Should I consider jacking the camper up to take the pressure off the tires? If so, what do you use to do this, how many, and where do you place them? Thank you.
0 ·
My understanding (perhaps incorrect) is that even if flat spots do form, they tend to work themselves out once you start rolling.
That said, I am interested in other responses to your question, as I plan to have my T@B up on blocks for a bit while I inspect and service the bearings.
the trailer is stored, put a 2x6 under each wheel to lift it out of the wet and mud. A gravel or paved surface will drain water away.
Weather cracking is a naturally occurring condition that results from exposure to heat and sunlight. Goodyear's warranty for weather cracking is four years from purchase date (or four years from manufacture date if proof of purchase is not available).
Weather cracking is common in RV tires from all manufacturers.
When should the tire be replaced?
Without evidence of weather cracking, use the following as a gauge:
Tampa FL
Urbana, MD
2020 Tacoma TRD Off-Road
Yes, modern tires do flat spot...and generally they will return to shape with use.
Amazon.com: Powerbuilt 3 Ton, Bottle Jack and Jack Stands in One, 6000 Pound Capacity, All-in-One Car Lift, Heavy Duty Vehicle Unijack, Wide Base, 620471 : Automotive
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
Tire Cradles, Set of 2 | Camping World
If so, I might pester the wife into getting one, because this is EXACTLY the same thing that was suggested to us for our Jeep for off-roading in the event you need to work on your rig.
Jay and Kat
Tow vehicle: 2022 Jeep Gladiator Sport S + tow package
Camper: 2022 T@B 400 Boondock w/Norcold 3-way fridge
Drop the front jack as low as possible
Lower the rear stabilizers
Raise the jack until the tires clear
Lower the front stabilizers.
As mentioned, the axel rubber torsion suspension will relax. Because of this, the wheels will drop an inch or more after a few days. If not lifted, the rubber begins to relax in the loaded position.
, but I think it disappeared from their manuals when they went more than 5ft wide.
"Just Enough"
