At last years NuCamp gathering, more than one seminar told us the most important upgrade was to install an Electrical Management system, like the Progressive Industries SSP-50X RV Surge Protector. I have researched some threads on this fine forum, and wanted to make sure, before I went to the trouble and expense of installing one, to make sure what I already use isn't just as good. Since we bought our 2021 T@B 400 BDL 2 years ago, we have been using a 30amp SurgeGuard Model 44260. It is has 2100 "joules" of surge protection.
1. this is what I am currently using....
2. This is the built in Progressive Industries one that costs $214, and looks a little involved to install. I don't even know where I would put it, under the bed?
3. This is another one made by Progressive Industries that just hangs on the post. Is it as good as the hard wired one? It is $168
4. and this is another brand that looks pretty good that is $68
Thank you for reading my post.
Personally, this isn’t something I’d cheap out on. Replacing your electrical system would cost you thousands, as would electrical damage to the Alde or fridge, and having a “hot skin” condition from being plugged in incorrectly could cause injury. Just my 2¢.
Here’s a thread with loads of opinions: https://tab-rv.vanillacommunity.com/discussion/14473/ems-vs-surge-vs-nothing
My 2¢ on the topic is: What You Have Now if Fine.
Why . . . .
A] What we RV'ers need to know is if the Park Power Pedestal is OK.
The basic unit like you now own does that.
B] In North America we have very good and stable power.
While over voltage, under voltage events can happen it is very rare.
C] I now have some 322 nights in my 320S with at least 80% of those at Public/Private Parks
that provided 120VAC power. In all those nights I have had one stop (2-night stay) with
a bad power pedestal, the 30A outlet would not display 'good' . . . so I used the 20A outlet
which was correctly wired or not broken.
In addition to the 30A Surge Protector and Pedestal Wiring unit (like yours) that I carry, I also carry a simple 20A outlet tester and a "hot skin" probe . . . . all three units together cost far less than a fancy installed unit.
Adventures: 51 Nights: 322 Towing Miles 41,200+
Just having a non-EMS surge though is not recommended since the biggest problems are low voltage, poor connections, and intermittent grounds. An EMS will cut the power automatically if any of those occur. A surge only will not.
2023 Ford Maverick XLT
The Finger Lakes of New York
2023 T@B 320 S Boondock
The Progressive Industries models with remote display have a by-pass switch for use with generators. The LCHW30 doesn't have that. One can find a simple remote bypass switch that gets wired to the EMS for generator usage. Also there's a diy hack we use with our generator that keeps the EMS happy.
Interestingly, there wasn’t that much difference in Mexico between the times the EMS worked and the times it didn’t. Reason being, the shore power was so wonky that when the EMS was working, it kept cutting the feed off: high voltage error, low voltage error, no ground detected, etc. Next trip to Baja we’re just going to boondock. Lots of sun down there, so that works.
Edit: We don't have this in our Tab, but it may be useful in a "pinch."
I found an installation thread on this forum, but it is for a 320, not a 400. I know @SLJ has all his stuff under his bed which is easily accessible. I would hate to put it under a 400 bed, because it is so difficult to access, but will, of course, if that is the only place. Would I put it on the driver side of the camper, in there where the water pump is? Where should I locate the LED remote display on a 400?
2021 T@B 400, 2018 Land Cruiser
Dallas, Texas
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view.” Edward Abbey
Our 23 T@B 400 has a drawer below the bed in the center. It fits comfortably behind that drawer.
One advantage to the hardwired EMS is Undervoltage protection to protect your circuit boards (Alde, A/C, fridge electronics.) I can think of five instances over several seasons where I posted unsafe notices and taped the covers due to ungrounded services or loose connections. Only one was physically full of water.
Undervoltage has triggered shutdown over a dozen times in three seasons. Several sites were simply not usable due to severe undervoltage due to poor field wiring or neighboring sites all using their A/C. We often see 50A rated large campers plugged into 30A or even 15A outlets and basically sucking the campground circuits dry.
I spot check shore power with a plug-in device first for polarity and grounding, then plug in the EMS-protected camper.
If you are experienced with wiring Romex, siting the EMS between the camper power inlet and the Wefco is not hard. On my 2021 had to move numerous haphazardly laid out wires and correct a great many electrical installation deficiencies.
Photo of our 2021 320S driver bay after significant rewire after first trip:
https://tab-rv.vanillacommunity.com/discussion/comment/182995/#Comment_182995
Digital readout installed on bath demising wall. Pull the Alde control and use the 3x3" cutout to fish from.
The readout is a BRIGHT red LED, a real pain at night. Since glued a plastic hinge atop the readout that I can simply flip down to cover it.
Dallas, Texas
Unlike your home, you don't need a electrician license, permit, and inspection on the (potentially hazardous)120v wiring in your RV. Manufacturers may voluntarily follow portions of the NEC but are scatty. If you haven't done compliant 120/240v wiring (called Low Voltage in industry) on your house there are plenty of requirements and field know-how to safely wire something without risk of short, arc, conductor damage or pull-out on a bumpy ride.
Anyone who has not done code-compliant house wiring would be well advised to get experienced help.
South Jersey
Do understand you are using a surge protector. An EMS does a lot more things. For where you camp, a surge protector may be a perfect fit.
"Just Enough"
Dallas, Texas
Dallas, Texas
https://www.amazon.com/gp/product/B088CWBBBM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
"Just Enough"
We've slept in 34 states, 2 countries & counting.
