TAB 360 == Fridge Brand & Model ?
MuttonChops
Member Posts: 2,058
nuCamp web site states a 5.0 cu ft 12v compressor.
I've not been able to locate that specific size with web searches so would a 360 owner share your Fridge, detail, information.
Isotherm Freeline Slim 140. It's a brand new model so there isn't a lot of public information about it. I loved it. 4 months of continual use, including three straight weeks of boondocking and it worked flawlessly.
Thanks
Mutton chops... I sense an interest in a new NuCamp! Congrats in advance.Yanni Lazarus 2020 T@B320S, 2018 RAV4 Adventure, Central CT0
I believe it was designed for the sailing community. Very solid performance so far. Came back from a month on the road with frozen food still in the freezer, mostly on solar. Very moderate power consumption, not real loud. It's very big and that works for us. No need for an auxiliary cooler.0
Gomers2, when you say "it" in your comment above, which fridge are you referring to please?
2018 T@B CS-S; pulled by a 2010 Toyota Tacoma v60 -
@RedDoorGals Gomers2 has one of the new Tab 360's, which uses the "Isotherm Freeline Slim 140" fridge that JkJenn mentioned above.If your question is in relation to your CS fridge and a possible replacement, this "Slimline" model will not fit.There are several threads that mention replacing the CS fridge. I believe your fridge is the 740BB?Look at this thread and the referenced "Truck Fridge". The Norcold fridges have very standard measurements, and many of the fridges designed for replacements tend to mimic the Norcold size and space needs.Here is a link to "Truck Fridge" that has many examples. https://www.google.com/search?client=firefox-b-1-d&q=Truck+Fridge+TF65Your Fridge may just need a simple thermostat. Check this link:
Towed by 2014 Touareg TDi1 -
pthomas745: thanks for your quick response. And yes, we have the old Norcold (well, not that old). The link you provided for the simple thermostat replacement is not a correct link (I don't think)...any chance you could refine that a tad? We think it's something "simple" and replacing the thermostat seems like it's something we could handle. (and we'd save replacing an otherwise functional piece of equipment...always our preferred option). Many thanks in advance. Have safe travels!
@reddoorgals sorry about the wrong link. I confused myself! I corrected the link in my post above. Check the model number of your Norcold fridge and we can help track down the thermostat. Some of them seem to be very easy to replace.
pthomas745 thanks for that new link...I'll research my fridge model and see if I can track down a new thermostat. Per another person's comment, I'll also check to see if the 12V fuse is good or kaput. Thanks again!
2018 T@B CS-S; pulled by a 2010 Toyota Tacoma v61 -
pthomas745 thanks for all your help; and just to help others, yes indeed it was just the 12V fuse for the refrigerator. Another lesson learned to check the simplest solution first (fuses!!). Thanks again
