Saw this in a recent post.
"Reminder, your breakaway brakes will not work with the battery switch off. Always leave the switch on while towing."
I believe this to be incorrect. My understanding is if you were to brake that connection ( or activate the breakaway system by pulling the pin while parked) you will have a battery drain, regardless, of the battery disconnect switch is on or off.
Need a straight answer. As I have been towing with the battery disconnect, switch off.
What does the wisdom of this forum say?
Thank you all.
2022 T@B400 BD behind Toyota Highlander XSE
I've always thought that my 2020 320S was the same. Has nuCamp changed this on newer or different models?
1. You can jack up one wheel with the trailer 7 pin disconnected from the TV. Trailer battery is ON (battery disconnect in ON position).
2. Pull the emergency breakaway pin on the frame and the lifted wheel should lock up with brakes activated.
3. Then turn the battery disconnect to the OFF position (trailer battery is OFF) and the power to the trailer brakes should cease and release the brakes, allowing the wheel to turn again.
Allowing a critical safety component to be disconnected by the owner due to the confusion you described is clearly not optimal. You would hope that a design is possible that would remove the human factor.
If the above procedure is incorrect I would really like to hear about it.
Thanks
PS: The circuit below does not include the breakaway switch, but shows the disconnect in line with the terminal going to the brakes
As @swiftwave noted other manufacturers may use different approaches. For example: InTech (Sol) trailers have an extra small rechargeable battery built into the break-away system so their trailers do not use/require the 'house' battery to be "on" {the extra battery needs to be tested on a defined schedule}.
nüCamp Trailers do require the house battery to be On:
How to Hitch and Unhitch Your Trailer
Hitching and unhitching your trailer might seem intimidating at first, but with a few simple steps, you'll be ready to tow with confidence. Whether you're a first-time owner or just need a refresher, this guide will walk you through the process and help ensure you're hitting the road safely.
Hitching Your Trailer
Follow these steps to securely hitch your trailer to your tow vehicle:
1. Align Your Vehicle and Trailer
Make sure your trailer and tow vehicle are lined up in a straight line. This helps the hitching process go more smoothly.
2. Adjust the Trailer Height
Raise or lower the trailer coupler using the jack so it clears the ball hitch on your tow vehicle.
3. Position the Coupler Over the Ball
Carefully move the trailer forward so the coupler is directly above the ball.
If you're working alone, you may need to back the vehicle up so the ball is directly underneath the coupler.
4. Lower the Coupler
Ensure your vehicle is in park with the emergency brake engaged. Use the jack to lower the coupler onto the ball until it is fully seated.
5. Secure the Coupler
Engage the latch to lock the coupler in place.
Remove the safety pin from the trailer jack wheel and insert it into the coupler latch for added security.
Store the jack wheel in the front tub.
6. Attach the Safety Chains
Cross the chains underneath the coupler before attaching them to the tow vehicle.
Crisscrossing provides a cradle in case the trailer becomes disconnected.
The chains should not be twisted. If they’re too long, use a quick link to adjust the length. These can be found at automotive stores or online.
7. Connect the Emergency Breakaway Cable
Secure the breakaway cable to the tow vehicle using a carabiner or clip.
Do not loop the cable through the safety chains. In the event of a disconnect, this cable activates the trailer's electric brakes.
8. Plug in the Seven-Way Connector
Connect the seven-way pin from the trailer to your tow vehicle.
Test your brake lights, turn signals, and running lights to ensure everything is working correctly.
Additional Tips:
Make sure your trailer is as level as possible. If not, you may need a rise or drop receiver.
Check that your battery disconnect switch is in the green/on position so the emergency brakes have power.
Once everything is secured and functioning properly, you're ready to hit the road!
Hi, Can not agree more, I find it totally unacceptable that is the case. When I had my 320, I wired it independent of the switch. It’s such an easy fix. In the world of safety hazard analysis , this would be an unacceptable risk requiring a fix.
Southern Maryland
https://tab-rv.vanillacommunity.com/discussion/comment/128424#Comment_128424
This link includes my wiring diagrams that show the path of both the trailer breakaway power and charge line:
https://tab-rv.vanillacommunity.com/discussion/comment/215901#Comment_215901
I have tested my 2019 320 S Boondock Lite to confirm that the battery disconnect switch must be "on" for power to be supplied from the trailer in the event it becomes unexpectedly disconnected from the tow vehicle (e.g., in a collision.) It is possible to wire it so that you always have power (with or without the switch "on"), but I see no value in doing that.
In my case, I prefer to always have power (from the trailer battery) available inside my trailer, including while towing, such as when I stop for a snack or some other reason, especially at night when I need light available inside the trailer. My 2025 Toyota Tundra includes an isolation relay, so when the tow vehicle ignition is "off," but the 7-way cable remains connected, my trailer is not pulling 12V power from my tow vehicle. This isolation relay is helpful, because I do not need to disconnect my 7-way cable when I stop somewhere for the night.
Also, if you are charging your trailer battery via the 12V charge line (included within the 7-way cable from your tow vehicle) while towing, you will want power to be able to make its way to the trailer battery (uninhibited by the battery disconnect switch cutting off that power.) Of course, if you prefer, you can install a separate charge wire (e.g., with a DC-to-DC charger) that eliminates that concern.
I did not use a multimeter to test the 7-way outlet on the Tundra with the ignition "on," and then "off." Instead, I was simply testing for power using the lights in the trailer to confirm power available from the charge line while the truck ignition was "on," but no power when the ignition was "off."
My 2¢
Inclusion of trailer 7-pin +12VDC isolation when the TV engine is not running varies widely by TV year-make-model and should be checked by every rig owner to confirm their actual wiring situation.
Unfortunately USA Manufacturers have tended to eliminate Trailer +12VDC Isolation Relays from their products in the past years. An example; for years & years a GM Built TV with the factory 'tow package' would have the relay . . . while my 2017 GM product does not. If fact it does not even have an empty relay position on the main fuse/relay panel. Part of the Big-3 overall programs to 1) reduce weight {yes only a few ounces} and 2) reduce build cost {increase greed profit margin}.
On the 2017 I installed my own isolation relay - - but when one considers the truck has many 'for towing' features like tow/haul transmission mode, suspension rake to reduce rear sag, increased radiator size, an additional transmission cooler, and the factory tow package . . . one would think the Isolation Relay would be included or at least just a simple aftermarket plug-in-it . . .
We live in a consumer driven economy with huge corporations focused on the lowest production cost, lowest feature set product the majority of buyers will accept . . . so we buy what is available and modify or live with the corporate profit driven 'close but no cigar' product offering . . .
In the 2020 and newer owner's manual corrected the error. The battery must be ON when towing. Because my CS has an electric refrigerator, we always towed with the battery on so the car could power the trailer.
"Just Enough"
