I purchased a 2015 TAB CS-S model last week and am totally frustrated with the lack of some important practical information in the TAB manual. The manuals for the individual systems aren't much better. For instance the Aldi manual is for the 3010 model I have but discusses the digital control panel. There is absolutely nothing in the TAB or Aldi manual to explain the slider-knob controls I actually have. Also, there is an on off switch to the left of the manual control for the heater and I have not idea what it is for. I could use some help on how to operate the controls for the heater and water heater, etc.
0 ·
http://www.alde.se/media/110714/v-3010-60-rev-1487-us-can.pdf
The other switch you describe sounds like the ventilation fan for the air conditioner. Switch it on when you use the AC to draw heat out of the enclosed AC cabinet.
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota
Durango, CO
If you cannot find what you are looking for you could also call the factory, ask for Ed Kauffman or Marvin Raber as both gentleman could easily walk you through the procedure you are looking for.
And as noted, the black switch controls cooling fans in the plenum area that pull hot air out and away from the A/C unit to allow the air conditioner to perform and cool more efficiently. make sure that switch is flipped on anytime you use your A/C unit in the trailer.
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
Central,Fl
2015 T@B Max-S
T@bbey Road
Appleton, WI
Our first outing was in Oregon last fall and the weather was very damp and cold. Once we actually figured out the Aldi it kept us very warm throughout the trip. That being said, we are headed out again next month and there's no doubt that we will struggle with it again!
As forum members make awesome mods and point out problems to the factory and folks there, things change. The company is the most responsive to customers I've ever encountered in my life! They listen, they must discuss bottom line and feasibility of implementation - then they do it! They find a way. I'm always impressed when a mid-production change for the better is implemented. However, the caveat is that it changes existing instructions.
I know all manuals are living documents. I work with a software product that changes as security upgrades are made to operating systems and other support programs on a weekly basis. That alone is frustrating. On top of that, it takes an act of congress to change our program features despite customer complaints and great suggestions - it's hard to get a small room full of people to agree on anything! Then someone has to volunteer to change the manual and remember to put in the other small changes that occurred along the way as security needs have changed. When PV and LG get their technical writers on board, I'm sure they will encounter similar frustrations.
My work's solution was to make an stakeholder email list that can alert our users that new things that have been implemented which would affect them and the date they started (most IT things just affect how I do my job - not our stakeholders). As far as document version control, we found that adding appendices for minor things that have changed prior to the next major rendition of the document works.
I love our forum expertise and how we work as a team. It's very hard to type a message that keeps the helpful tone of a member and also not put someone on the defensive. I think our forum is comprised of a select group of geniuses. I thank you all. I have learned so much.
My qualifying line:
TL;DR - this forum and members are awesome.
"The fan you hear from the converter is a cooling fan for the converter. It should run a little while when first charging and when first plugged into 110V power. Also occasionally during use.
There are 12V fuses in the converter that may be blown, and there is a fuse on the wire going to the positive side of the battery at the battery. Check to make sure those fuses are still good. And, there are circuit breakers in the converter that should all be turned on. Try checking those."
Now off to find that fuse by the battery fuse.
Btw, thanks Verna.... If you are reading this...
Also, I'm one of those who never had a trailer. Learning how to hook it up, how to drive and also backup with one, internal systems, finding a place to store it, checking the battery, the waste system, and the fragmented information given by the manuals and our dealer. We spent 42 years tent camping, first in 2 man, then, 3, and finally 6. There was a certain simplicity there. BTW, I love that homemade manual the couple put out... Our dealer told us to twist the hookup chains to shorten them, now I read that's a no no. He said to keep holding in the igniter for the fridge until it starts, when the manual states 30 seconds, it can explode. He said, just open the solar panel package later, it's self explanatory. Just plug it in. Sorry, I didn't have a manual, and I see battery clips, not a plug. We called, and were told, well, down the cable there is a join. Disconnect and there is your plug... How was I supposed to know that...?
Anyway, don't get me wrong, we are happy with our T@b and glad to have purchased it.. We are going to love it.
And yet, I remember those simple days at age 20, my soon to be wife, my car, and my two man tent.... Smile....
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
I understand the "oh btw, you need to.... " or "Oh btw, you might want to know that...." After the 15th one, your hair starts graying at an exponential rate (or falling out, depending on your genetics).
Hang in there!! If I had time, I'd write something similar for the T@Bitha, but I'm not always privy to the minor changes that happen in the factory (or change in manufacturer suppliers for certain parts). Alas. We have it good here.
Oh, and MANY more happy camping days in the T@B than your tent ever gave you
Anyway, you're very welcome for the converter information. That and experience is how I learned. I always recommend that new owners read, read and read some more. When you find conflicting information, look a little farther and if still confused, ask.
As as far as the many posts on one subject....this is why many of us ask that the members search. If you put your question at the end of that found discussion, there will be fewer discussions to search. But it doesn't seem to work that way, so the 80 finds on a search will continue.
Central,Fl
2015 T@B Max-S
I'm not complaining myself. I'm a happy camper.. Haven't seen any published T@B books though.
T@bbey Road
Appleton, WI
Richard Lewis, a long time T@b owner did write an e-book, but he owned a Dutchman T@b. http://amzn.to/1UQeS22
I have to say the adventure should be seeing the country and meeting new people, not spending hours figuring out how the trailer works.
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
Most people hate their owners manuals because they have the wrong people writing them.
Current market trends for all industries is for the business to become more buyer focused. LG and PV are extremely buyer focused. Scott Hubble even publishes his cell phone number. I am also not aware of any other RV distributor that has a dedicated owners forum.
