I'm currently at a State Park camping with sis. Does anyone know why the water pump would do this? It's the same jackhammer water pump as everyone else (adding some insulation is on my to-do list). I'm on 30A shore power. No city water. Tank is full. Pump pressurizes the water as per usual. It can't be drawing so much power that the lights flicker. Have multimeter, will check everything if some of our more versed RV technical gurus can give me a hint as to where to begin to look.
Thanks!
0 ·
My hard-wired meter to my battery says 13.7V, so converter seems to be in charge mode (I think this is normal if the battery is used as a buffer). All AC outlets work. Air conditioner turns on, so the AC side is working.
I need to check level of fresh water tank. Could be low, making the pump work harder. Is there any way to fill the fresh water tank from a container easily by hand (have fresh water container)? I'd hate to have to carry around a separate pump.
If there's any change this weekend, I'll let you all know! BTW, did check wires in ground/neutral blocks... nothing loose.
Ratkity, this is the easiest, less wasteful way I found to add water to the fresh water tank. I used a 4-gallon jug, I replaced the stock on/off valve with a brass 3/4" faucet bib, and then I screwed the 12" tube from Amazon or Camping World to the bib. Stick it into the water inlet, and open the lever. Very little waste, slower than using a water pump (or my battery operated shower), but very efficient.
I was able to get 3 showers, washing hands and dishes in the 19 gallon gray water tank. The 11 gallon fresh water tank need 2 to 4 gallons per day, depending on how much I was inside during the day. The black water tank would last 5 to 7 days....depending....
St_Bob, thank you! Made me feel better to read that the pump/light flicker isn't something to panic about and the marine forums were helpful as well when talking about LED and water bilge pumps and light flicker.
Side note: Alde touch screen upgrade is da bomb - love it!! Rotated my bedding to sleeping on the back futon near the heater vents with head on driver's side and feet towards opposite side wall. I fit perfect! Other observations - We are having 20 mph gusts and the XL Visor is doing well, although I hear it flap periodically and check on it just in case. I can also watch my sisters Visor XL because she's in the spot across the street. Snugged her's up a bit, but all seems to be doing well. We've had rain/snow/sleet and a wee bit of wind this weekend. Toasty and warm!
