We are going on Saturday to pick up our new T@B. We've never owned one before and have done a lot of research on the topic of setting up for the camp sites. I have reviewed several posts that talk about the Anderson Leveler as well as posts that talk about the Bal Levelers. I wanted to hear some pros and cons on each to determine which one may be right for us. By the way, my wife and I will going out with the T@B, not looking for any solo trips. So, there will be two of us to assist in the leveling process. Anyway, I see where both are good products, just not sure which may be right for us. I thank you in advance.
Marc & Janet
2016 T@B Max S - 2017 Honda Pilot - Magnolia, TX
0 ·
I have a BAL, which I love, but that is because I do a lot of solo trips. It takes a lot of cranking to get the trailer level, it is an odd size and a challenge to store at times, and it is heavy. But it is easy to use otherwise, and beats the blocks hands down.
The Anderson only works well if you have two people, one to drive the TV, and one to signal when it is level. Nice thing is, it is as simple as backing up a foot, give or take, to get it level. Then it is choked and done. Takes seconds. Also seems to be lighter and easier to store from what I can see.
Sterling, VA
I'll throw another one in. I'm a solo camper and I love my Legos -- Stacking Leveler Blocks. They are easy to use with one or two people. I spent all winter in AZ and I never needed more than one package of 10, even though I did buy an extra 10 pack. Why are they called Legos? Because they connect together like Legos so that they stay in place. Right now, they're just under $30 on Amazon.
Also, the thing that runs best being level is the fridge and it may be off a little from the frame or floor. I get my fridge level and then apply the Camcos.
Back into site, get out, check left/right level (each tickmark on the Camco = one block, retrieve and lay down necessary blockitudes, back on and bingo, done. Unhitch, crank jack for front to back leveling. One thing that comes in handy is a half inch block/board for a fine tune since the blocks are one inch. Putting a wheel chock down prevents you from backing to far and off the blocks. If one is on real soft sand it might take one extra as the first block sinks to subsurface.
J.D. & Sue
Yeah - what voltage indeed? My 18V cordless poops out with the BAL. Works great on the stabilizer bars, tongue jack and drill bit for tent stakes.
The biggest advantage with blocks is you can level without unhooking, even use them to raise the back of the vehicle if need be. Most versatile leveling system there is.
J.D. & Sue
Sterling, VA
If you're style of camping is mainly in campgrounds or always on relatively level ground BALs or Andersons will work for ya but there's nothing more versatile than blocks.
Typical adaptor:
http://www.amazon.com/DEWALT-DW2542-4-Inch-8-Inch-Adapter/dp/B0000225P5/ref=sr_1_3?ie=UTF8&qid=1461279237&sr=8-3&keywords=3+8+socket+drill+adapter
J.D. & Sue
J.D. & Sue
Again, it really comes down to what kind of camping you are doing. PXLated, you are camping in unusual circumstances for most folks with a T@B. Sure, there are others like you, but most folks are going to set up in a campground or someplace a little less off the grid, even when boondocking, then you. Most folks are going to want an easier solution that fits the kind of camping they are doing. I think the original poster has already decided they would like either a BAL or an Anderson, since that was the question. Going around and around about the virtues of blocks really is not answering the question, it is just saying how awesome you think blocks are.
I will stick by my answer, I love my BAL, but I think with their described circumstances the Anderson will serve them better.
Sterling, VA
Photomom - Yep - This discussion/argument happens on a regular basis. New members ask, everyone responds :-)
