Our T@B was unplugged all last week so I could monitor battery voltage under the parasitic load. It was down to 12.3v yesterday so I plugged in to house A/C to recharge. This afternoon we unplugged and checked to make sure the battery was charged. The SeeLevel monitor had no power, and interior lights wouldn't come on. Everything works fine when the trailer is plugged in to A/C.
I checked the battery and it is at 12.6, but when we pulled the battery fuse, it had blown. It is a 15A fuse.
So between yesterday afternoon and this afternoon, something happened to blow the battery fuse. We haven't even been in there. The ONLY thing that has happened is we got a couple of heavy rainstorms today, but it is hard to understand how that could be the problem. I noted that the battery cutoff switch is quite wet, but I understood that those were meant for marine use and I'd think it would be sealed.
Will buy fuses tomorrow (thought I had some but they are the "mini" size.) But in the meantime, what should we be looking at?
0 ·
A wet switch is enough to blow the fuse if they are switching the positive lead from the battery. I have my switch mounted on the rear cross piece that is directly under the lid to keep it dry. It has not gotten wet in all of this rain and storms we've been having.
Also, isn't that supposed to be a MARINE switch?
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
I can can buy that we might have the wrong fuse, but we've had this a couple weeks and have camped two weekends. And this isn't the first time it's rained, or the first time we've charged the battery!
The slight surge from the converter/charger could easily have been over 15A. I'm pretty sure the battery fuse should be 30A.
Happy Trails Y'all
I suppose we could go by the wire gauge/length it's protecting, to determine the fuse required.
Or contact the manufacturer.
If you look at the fuse amperage designations on PXLated's converter, the last 12V fuse is designated as "Battery Charger" and it is a 30 amp fuse. You should protect one fuse with the same size fuse, right ? Therefore, a 30 amp fuse should be in both places--converter and the battery.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
I was an electronics tech in the service and put myself through college repairing computers. No gremlins, there's a reason for everything. In this case I'm not surprised the reason is the dealer put in the wrong fuse, given some of his other mistakes.
"If there is an electrical problem, first check the 20-amp fuse at the battery then check the fuses located in the converter. Do not replace battery fuses with anything other than a 20-amp fuse."
Of course, the manual is outdated, and appears to cover more than just the T@B.
My 2015 has a 30A fuse at both the battery and the converter. The wire connecting them is 10g, which is rated for 30A. So, like everyone else, I say go with a 30A fuse!
Thank you, Henrietta, for your service! Which branch of the service? My Daddy was one of the Chosin Few in the Marines, having served on the Korean War.
