Best toilet treatment for a T@B S!
Connor2008Connor2008 Member Posts: 12
i have listed this question on a thread that seemed loosely related and searched with every combination of words I can think of and have come up empty so I thought I would start a new one.  Any suggestions for the best toilet treatment/chemical to use in a T@B toilet.   Most products seem to be for 40 gal grey/black water tanks. I'm pretty sure our T@B S tank is <20 gal. Suggestions?  Thanks.  Brand new owner.
Dan & Nancy   Vermont   Orange/Silver 2013 S--Dre@msicle--TV 2013 Tacoma 4x4.
Nights spent in T@b
D   6
N   6
    Good question - When you hit an RV store or Walmart there seems to be an endless assortment/variety all with basically the same description on the package. It's almost a lost cause trying to pick one. Might just as well close your eyes and grab.
    edited June 2016
    You're right Connor2008, the Tab S black tank is @ 5gal.
    We use Arm & Hammer Super Washing Soda, enough to soften the water a bit, and put a gallon or so in the tank when it's empty, so things don't stick in there when you use it.. It also says it deodorizes, and we've never had a problem with smell.
    I make a concentration equivalent to a strong washing solution, about 1/2 cup per gallon, so it stays effective as it gets 'diluted' as we fill the tank.
    Connor, I found I didn't like the results of the small blue bottles, although they are the most economical. I picked up the orange packets at Walmart, and even though they are intended for the big guys, they do keep the odor down and seem to ummmmmm...... break up the solids.
    It seems the Camco brand is the one that you can find at just about every RV business and Walmart.
    It's a trial and error and what your nose can detect.
    And don't fall for the 'ice cubes clean out your tank' myth... A guy did a test, here:
    http://www.thefitrv.com/rv-tips/do-ice-cubes-in-the-rv-black-tank-really-work/
    edited June 2016
    I love the Happy Campers stuff. I just put in 1/2 - 1 scoop.
    I do the disolvable packets but no particular one - Close my eyes and grab. Only time I've ever had an oder was after a dump one time.
  • cbarnhillcbarnhill Member Posts: 330
    ROFL.  Sorry, dirty mind. ;-))
    Cindy with my 2015 MaxS (Puppy) and my 2015 Subaru Outback (Boo)
  • Connor2008Connor2008 Member Posts: 12
    Excellent, thanks everyone. I'll close my eyes and grab or I'll get the orange packets because they will match the Dre@msicle!  Thanks again.  I love these groups.   :)
    Nights spent in T@b
    D   6
    N   6
    Really PXL? :o
    Short for "Dump Station" - Jeeeeeeese you guys.
    Ok. Better stick [OOPS!] with that story! ;)
    Must.sedate.brain.cell.OMG.the.four.year.old.poop.jokes.are.trying.to.escape!!!
  • kybobkybob Member Posts: 232
    We use Odorlos. There is no odor from the product as well as the tank.
    2018 Outback S, Silver/Black - 2015 Silver Honda Pilot 4WD - Florence, KY
  • Mr_Mrs_GnomeMr_Mrs_Gnome Member Posts: 241
    @kybob, what version or Odorlos, liquid or dry? Read a report about the concentrated dry on a plastic fitting causing plastic to soften.
    We started with liquid and now use the dry that comes in a bucket. We put a scoop in and add a little water. I don't like the smell the other chemicals put out. They make my nose itch.
    Thanks. Will do.
    Nights spent in T@b
    D   6
    N   6
  • JustjudyJustjudy Member Posts: 75
    How much water does it take to cover the bottom of the black tank? I have read that the bottom should be completely covered by water before the treatment is added. I don't want to put in TOO much water, since the tank capacity is only 6 gallons.
    Larry and Judy. 2015 T@B S M@xx. Silver with black trim. Bell@. Towed by a 2005 Toyota Tacoma.
    Judy, I pull the lever for about the count of two normal flushes....if you can figure that out. The black water tank lasts me for 7 or 8 days, one person.
    edited June 2016
    I just pour in a gallon.
    A cup full will cover the bottom but it will only be 1/32" deep.
    How deep do you want it :-)
    Ha! How deep do I want it?
    Thanks for the help. I appreciate it.
    Kinda wish we could flush with gray water rather than fresh. When I was in Afghanistan during a drought, we were rationed to a quart of water to bathe in daily. We stood in a plastic kiddie pool and then collected the gray water to flush poo down the commode (we had a western style toilet). The paper from cleaning up business was collected in a covered trash can next to the commode and then taken to a burn pit.
    Would it be possible to dump the gray water into a bucket and use that for flushing?
    I would think if you purchased a gray water cap with a hose adapter built into it, you could stop the flow enough to be neat about draining just a bucket full of gray water. The gray water comes out of the "chute" so quickly that it would be hard to contain without an adapter.
    This is a great idea when you need to go else where to get water and and even better idea when you have to pay for water.
    You could put a little valve on that hose to controll the flow.
    How about something like this?
    There are RVers out there who do recycle the grey water and have elaborate systems to catch it in their showers, if you do a web search.
    Yes, that is what I was trying to describe. I bought a shut off for the end of the hose (probably should put it on this attachment) so it can instantly be shut off. My gray tank fills up quicker than the black, so if I use the gray for flushing, that will save me a day or so between dumps. Walmart has 5' black hoses so you can keep your hose uses separate.
    I have my 2 small portable (5 gal) waste tanks. With those, I can manage 2 weeks before needing to go to a dump station. I only use them for grey water.
  • BNAG8RBNAG8R Member Posts: 5
    Had our first camp this weekend with the new T@B.  Learned a lot on the "shakeout", but had a question for the forum re black water tank.  Emptied and flushed the tank, then added about a gallon of fresh water with a "porta-pak" deodorizer before leaving the campground.  My T@B will be in stored covered for about 2 weeks this way before I use it again - will this be ok? Any issues with storing it this way?
    You'll be fine!
    J.D. & Sue
