Norcold Fuses
Tabaz
Member Posts: 2,420
Does anyone have the model numbers for the three Norcold fuses AND the cheapest place to get them?
hey, outbackaz don,t know a place to get them... (1) 3amp type 3ag---ac circuit... norcold part # 61654622..... (1) 20 amp type 3ag--- dc circuit norcold part # 61440522.... (1) 1 amp type 3ag-- gas circuit norcold part # 618079.... I hope this helps, Manny...2015 L-max2017 T@B CS-S Max ... 2020 Honda Ridgeline RTL-E1
Yes it does - thanks so much Manny!2016 Outback 320
Let us know where you find them Frank - TIA0
They almost look ike standard glass tube fuses. I wonder if we really need the specific Norcold ones.
2014 T@b S Max AKA T@dpole0 -
Yes, I know - Am being lazy and hoping someone would post the page links so all I'd have to do is put them in the cart :-)0
outbackaz... just came back from Camping World.. I have one 3 mins from my house... They had assortenment of those glass fuses.. I have not physical looked at the fuses for the fridge.. but they should work...2017 T@B CS-S Max ... 2020 Honda Ridgeline RTL-E0
I was asked not to post Amazon links.PXLated said:Yes, I know - Am being lazy and hoping someone would post the page links so all I'd have to do is put them in the cart :-)2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
Because you're an affiliate?John and Henrietta, Late 2016 T@B S Max in Western New York0
It's a rabbit hole I am not going down. Those are LG'S wishes and I am happy to abide by them.Photomom said:Because you're an affiliate?2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
Jenn - are you saying the Norcold fuses are available at that A to Z place?2016 Outback 320
Ya, if you're an affiliate, technically you're selling and advertising.0
Removing the cooktop is VERY easy. Turn off propane at the bottle, remove the Fridge blade fuse from the fuse box on the passenger pedestal, snap off the four plastic bumpers under the glass cover, remove the four screws holding the cooktop to the counter, use a plastic putty knife to break the caulking bead, then lift the cooktop out and over to the sink. Some photos below. Hopefully Photomom can provide a source for spares with the description below.
Pull the Fridge blade fuse (#4 position - see label on cover):
Use a plastic putty knife to break the caulking bead:
Simply lift the cooktop out and place over the sink:
Red arrow points to fuse location. Yellow is the thermocoupling (FYI only):
Arrow shows plastic cover over the 3 fuses:
Fuses with plastic covers removed (1amp fuse already pulled)
They look pretty standard to me (32 cm long):
Close up next to a ruler:
2024 Ford F150 Supercrew short bed.1 -
Excellent. I am about to leave for a 2 week T@Bventure and will do some research when I return.John and Henrietta, Late 2016 T@B S Max in Western New York0
Oh, we're they all that gold color?John and Henrietta, Late 2016 T@B S Max in Western New York0
They look silver in the other pics.0
Photo is deceiving - the metal ends are SILVER.2016 Outback 320
Loosely related question...
@OutbackAZ, did you install the wooden corner blocks into which the stovetop corners screw? Mine (2015-S) had these miserable fussy little clamp-thingies that are supposed to rotate into place and grab the underside of the counter as you tighten the screws. Some did, some didn't, making the whole removal and reinstallation more aggravating than it needed to be. I think I might upgrade to what you have; maybe even install some threaded inserts to catch the screws...
Interesting. The online photos at the RV place all look gold. To justify the price?
John and Henrietta, Late 2016 T@B S Max in Western New York0 -
Just noticed I pulled the wrong blade fuse. The #4 position relates to the circuit breaker. The fridge is the blade fuse in the #2 position (15 amp). DOH!2016 Outback 320
Hmm. Why is there a 15 amp blade fuse in the box and a 20 amp on the fridge?2016 Outback 320
Nice picts! Thanks!!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
OK, just ordered all three fuses from Amazon for $27 including shipping (2 are 5 count packages and one is a 3 count).
BTW, please ignore the dirty cooktop in the photo above. Did not have time to clean it after the last campout!
Scott - the wood corner blocks are factory installed.2016 Outback 320
Interesting, Outback-- great pics, BTW. Our '04 Dutchmen T@B has a different stove, but the one in your pics is exactly the same as the one in our 2015 Roadtrek SS Agile. (I actually prefer the older one in our T@B.)
Just to be clear these fuses are 3.2 cm long and .6 cm in diameter or 32mm x 6mm. The heading on the diagram states 32cm x 6cm and that is one big fuse.2016 T@B M@X S grey/red 16 Foot Airstream, towed by 2014 Jeep Grand Cherokee V6 4x4, Central Connecticut
Lapowers57 - You are correct. I simply counted the hash marks on the ruler. Here is a photo from Amazon from one of fuse packs I purchased:
