Norcold Fuses
Does anyone have the model numbers for the three Norcold fuses AND the cheapest place to get them?
  • manny
    manny Member Posts: 108
    hey, outbackaz   don,t know a place to get them...   (1) 3amp type 3ag---ac circuit... norcold part # 61654622.....   (1) 20 amp type 3ag--- dc circuit  norcold part # 61440522....  (1)  1 amp type 3ag-- gas circuit  norcold part # 618079....    I hope this helps,     Manny...2015 L-max
  • Tabaz
    Tabaz Member Posts: 2,420
    Yes it does - thanks so much Manny!
  • Nomad
    Nomad Member Posts: 7,209
    Let us know where you find them Frank - TIA
  • ChrisK
    ChrisK Member Posts: 280
    edited July 2016
    They almost look ike standard glass tube fuses. I wonder if we really need the specific Norcold ones.
    2014 T@b S Max AKA T@dpole
  • jkjenn
    jkjenn Member Posts: 6,424
    Amazon
  • Nomad
    edited July 2016
    Yes, I know - Am being lazy and hoping someone would post the page links so all I'd have to do is put them in the cart :-)
  • manny
    outbackaz...  just came back from Camping World..  I have one 3 mins from my house...   They had assortenment of those glass fuses..    I have not physical looked at the fuses for the fridge..   but they should work...
  • jkjenn
    I was asked not to post Amazon links.
  • Photomom
    Photomom Member Posts: 2,217
    Because you're an affiliate?
  • jkjenn
    It's a rabbit hole I am not going down. Those are LG'S wishes and I am happy to abide by them.
  • Tabaz
    Jenn - are you saying the Norcold fuses are available at that A to Z place?
  • jkjenn
    Yes
  • Nomad
    Ya, if you're an affiliate, technically you're selling and advertising.
  • Tabaz
    Removing the cooktop is VERY easy.  Turn off propane at the bottle, remove the Fridge blade fuse from the fuse box on the passenger pedestal, snap off the four plastic bumpers under the glass cover, remove the four screws holding the cooktop to the counter, use a plastic putty knife to break the caulking bead, then lift the cooktop out and over to the sink.  Some photos below.  Hopefully Photomom can provide a source for spares with the description below.
    Pull the Fridge blade fuse (#4 position - see label on cover):
    Use a plastic putty knife to break the caulking bead:
    Simply lift the cooktop out and place over the sink:
    Red arrow points to fuse location.  Yellow is the thermocoupling (FYI only):
    Arrow shows plastic cover over the 3 fuses:
    Fuses with plastic covers removed (1amp fuse already pulled)
    They look pretty standard to me (32 cm long):
    Close up next to a ruler:
  • ChanW
    ChanW Member Posts: 3,165
    Great info graphic, OutbackAZ.
  • Photomom
    Excellent. I am about to leave for a 2 week T@Bventure and will do some research when I return.
  • Photomom
    Oh, we're they all that gold color?
  • Nomad
    They look silver in the other pics.
  • Tabaz
    Photo is deceiving - the metal ends are SILVER.
    ScottG Administrator Posts: 5,683
    Loosely related question...
    @OutbackAZ, did you install the wooden corner blocks into which the stovetop corners screw? Mine (2015-S) had these miserable fussy little clamp-thingies that are supposed to rotate into place and grab the underside of the counter as you tighten the screws. Some did, some didn't, making the whole removal and reinstallation more aggravating than it needed to be. I think I might upgrade to what you have; maybe even install some threaded inserts to catch the screws...
  • Photomom
    Interesting. The online photos at the RV place all look gold. To justify the price?
  • Tabaz
    Just noticed I pulled the wrong blade fuse.  The #4 position relates to the circuit breaker.  The fridge is the blade fuse in the #2 position (15 amp). DOH!
  • Tabaz
    Hmm.  Why is there a 15 amp blade fuse in the box and a 20 amp on the fridge?
  • Ratkity
    Ratkity Member Posts: 3,770
    Nice picts! Thanks!!
  • Tabaz
    OK, just ordered all three fuses from Amazon for $27 including shipping (2 are 5 count packages and one is a 3 count).
    BTW, please ignore the dirty cooktop in the photo above.  Did not have time to clean it after the last campout!
  • Tabaz
    Scott - the wood corner blocks are factory installed.
  • irvingj
    irvingj Member Posts: 335
    Interesting, Outback-- great pics, BTW. Our '04 Dutchmen T@B has a different stove, but the one in your pics is exactly the same as the one in our 2015 Roadtrek SS Agile. (I actually prefer the older one in our T@B.)
  • lapowers57
    lapowers57 Member Posts: 186
    Just to be clear these fuses are 3.2 cm long and .6 cm in diameter or 32mm x 6mm.  The heading on the diagram states 32cm x 6cm and that is one big fuse.
  • Tabaz
    Lapowers57 - You are correct.  I simply counted the hash marks on the ruler.  Here is a photo from Amazon from one of fuse packs I purchased:
