Kidding aside, that's a common plumber's level and it works great. It's compact, sturdy, accurate, has a grove on one side for fitting to rounded or ridged surfaces, and a magnet on the other so it doesn't keep falling off your tongue. (Trailer tongue, that is...)
Mine helped build my house almost 20 years ago. Now it enjoys a cushy retirement "camping" full time in the T@B. (Wish I could say the same...)
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
PXLated mentioned using blocks under the wheels to raise the trailer when one could not lower the front jack enough to level the trailer. I use a BAL leveler and I ran into this situation once. Simple solution was to spin the T@B 180 degrees. But I was wondering if you could raise the jack, support the trailer temporarily on the front stabilizers, remove the front wheel and crank the jack back down onto a stabilizer pad. I guess there are two questions. Will the stabilizers support this weight temporarily ( I think so based on other threads) and second would it harm the front jack to use it with out the wheel but with a stabilizer pad under it?
2016 T@B M@X S grey/red 16 Foot Airstream, towed by 2014 Jeep Grand Cherokee V6 4x4, Central Connecticut
You could do all of that, or you could just carry a couple of these with you:
Couple of wood blocks is what I lower the jack on nearly all the time, never had a problem. The other option available is a foot:
Sterling, VA
Sterling, VA
