Pleasant Valley has sent me 4 .pdf files for winterizing different years and models of T@B's. Plus the directions to the analog thermostat.
My problem is that I have not been able to copy and paste the .pdf files to the forum. How do I do it? I'm obviously lost on this one.
Thanks
0 ·
Then I click the button that says "Choose Files".
That brings up the 'system' file chooser, be it Android, Mac-OS, or Windows. Then I navigate to where the file is on my system, and select it.
The written directions say to start by opening the drain valves on pages 2-3. Page 2 has a photo of the valves and the caption says the valves are only needed if you're using RV antifreeze to winterized. Which is it? I have no idea how to do this and the instructions are not clear at all!
On a related note, the fourth image on page 3 is also misleading. It says you do not need to use the Alde safety relief valve (yellow flap thingy) to winterize. While that may be true with regard to blowing lines or adding antifreeze, you do need to use this valve to drain the water in the Alde HW tank prior to winterizing.
