j_ntabowners
Member Posts: 131
Hello, My wife and I tried to use the Alde heater in our 2015 t@b over the weekend on propane and battery and couldn't get it to work. Checked the fuses and all were good. Battery charged, propane ok (stove burned hot and strong) - [don't worry we didn't use it as heat source
], and plenty of water in the tank No red light on the thermostat. Anyone have any ideas. Do they get vapor locks?
(shore power, no propane and cabin and water heat. The temperature setting is at around 70 degrees (between 3 and 4).
Fred
Tulsa, OK
2017 Tab S Max Outback silver/silver
I found my problem, but I think I'm on my own for repairs. looks like the water supply line into the Alde unit was shut off, When I picked up my brand new t@b at the dealership last April it was winterized, but I was a newbie, and didn't realize they must have shut off the supply line when they drained everything. We used the heater once a couple of months back, and it worked, then when we went to use it last week-end it wouldn't work. Last night I opened up the storage area and I found the closed supply line. My heart sank. Not sure what kind of damage it sustained by using the heater without having that open, but I'll take it in and find out.
Thank you for that good news. Yes, I did put water in the system, and still nothing. I think my next step is to look for the fuse(s) that's on the heater itself and check.
2014 T@B CS Maxx
Martha Lake, WA
Condo A-Go-Go
2017 Tacoma (AH GOGO)
S. UTAH
The worst that will happen is that the 15 amp breaker on your garage circuit might trip if you use the three "lightening bolt" setting. Stick to one or two lightening bolts and you should have plenty of juice.
I'll spare you the lengthy explanation, unless you care... :-)
Condo A-Go-Go
S. UTAH
Watts (the amount of "work" produced) is equal to volts (pressure) x amps (flow). Volts remain constant (120 in this case), so a higher wattage device will demand more amps. And--as you correctly noted--wire of a certain size can only accommodate so many amps before it overheats and creates a fire hazard. Circuit breakers and fuses disconnect the power before this occurs.
Therefore, your capacity to do work is limited by the smallest wires in the circuit. While your 20 amp rated T@B wiring can accommodate 2400 watts, your 15 amp rated garage wiring can only accommodate 1800 watts.
You are also correct about the lightening bolts. The Alde has two 950 watt heaters. Turning them both on (three lightening bolts) draws 1900 watts. Since this is a little over the rated capacity of your garage circuit, you might trip the breaker (or blow the fuse) on that circuit. However, if you turn on only one of the heaters (one or two lightening bolts), you should be able to test your Alde while remaining well within the capacity of your 15 amp garage circuit.
I think that may be the part missing to verify capacity.
Condo A-Go-Go
S. UTAH
