In a little over a year I've broken both black and grey water caps. Been as carefully as possible putting caps back on ( I'm not that strong ) but the bayonets just break off with little effort. Is it me or have others had the same problem?
I've had 3 broken - One had a cracked and evently broken bayonet (black tank), another two just disappeared mysteriously on the road (one black and one gray). The current one that is troublesome is for the gray and is loose connecting to the nubs. I put a piece of paper to make the cap tighter as a "on the road" fix. Not sure what I'm going to do in the long run.
Both the originals that came with my T@B broke after one season. I replaced them with a different model that had four robustly attached bayonets (vs. two flimsy ones). Thus far, both seem to be holding up fine.
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
I agree about getting the "four banger". It is much stronger than the two!
Verna, Columbus, IN 2021 T@B 320S Boondock “The T@B” Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”
I'm pretty sure I ordered the Camco 39452. It's similar to the one SAM posted but without the hose connection.
If you look carefully, you will see there is quite a bit of plastic attaching the bayonets. The one I replaced were pretty skimpy in that area, and that was where they cracked.
$3.77 + tax in the RV section at Walmart. I just replaced the one with the hose connection I Garvey away. I just get the hose connection ones because I want it for the gray water, but definitely NOT for the black water, and I don't have to keep two on hand.
You're just too manly sabel :-)
2022 Ford F350 Tremor | 2022 Cirrus 620
Started putting a spare in the T@B.
Sterling, VA
Camco 39463 Sewer Cap with Hose Connection available at Amazon.
2014 T@B CS Maxx
Martha Lake, WA
