Has anyone noticed the air conditioner box is not insulated and has gaps at the opening? I believe I am going to install thermal and acoustic insulation silver sheets to provide some insulation.
                M@rk and Donn@ : 2015
T@B S Max, Silver/Black, 2008 Toyota Beef Taco DC
I definetly notice a draft coming in around the AC when I have a good wind so sealed the gaps between the the AC unit and the frame inside.
Have you seen a listing on the Teardrop shop for the after market, snap on air conditioner cover for the wall mounted AC. Which category is it listed in?
Jeff
M-F 5;30-3:30 EST. Ours was $24.22 plus shiping and came with snaps you install on the frame.
(9/22/19/
2015 T@B M@X S. . . he, she will name itself on the next trip. . .
(9/22/19/
(9/22/19/
I had my water heater cover get blown off once in Wyoming during a severe windstorm. Therefore I wanted to make sure my AC cover, which would be on for most of the year, stayed put. I also wanted to be able to remove it without any tools. Yes, 8 screws is probably excessive, but that's what engineers do best :-)
Here's the first version:
The recipe:
1. 1/4" plywood, painted black, coated with urethane
2. auto/marine window seal glued to inside of cover
3. wing screws (10-32), 3/4" long
4. large washers
5. drilled, then tapped holes in the metal grille face (to same threads as wing screws, 10-32)
I wanted to try wood first, since it was easiest for me to obtain and work with, but aluminum or plastic would be a nice version 2, if the wood ends up rotting. But there's no way it's blowing off!
