Got kicked out of my garage this winter because of a car. So, I have the option to store my rig next to my house or in my wooded yard. Considering the snow, leaves, rodents, how close is too close, etc. No cover this season, in northern Ohio. What would you do?
emily . northern ohio . 2015 320s . jeep wrangler
0 ·
I've noticed that when we park under the maples, it tends to get a good coating of detritus from the tree.
I'd rather keep it out of the barn, so I can use the barn for other things (DW doesn't agree however)...
I've been told that heated spaces tend to attract mice. Maybe don't heat it unless you want to use it.
Sterling, VA
2014 T@B CS Maxx
Martha Lake, WA
"Growing old is mandatory. Growing up is optional."
I wonder if there is something made expressly for this purpose that has hard rubber rollers.
2022 Ford F350 Tremor | 2022 Cirrus 620
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
My "portable garage" is a Shelter Logic 10x17 sold by Harbor Freight. It lists for about $200 but is often on sale for ~$170.
The frame is bolted to the concrete blocks for stability and the extra height needed for overhead clearance. I added some wooden 1x3 diagonal braces to keep the frame square and stable with wind and snow load (about 100" a season around here).
The cover started showing signs of failure at the high stress points at the frame corners after the forth winter. It is possible if I had adjusted the tension on the cover it may have lasted longer. It turns out a new cover is more costly than a new complete shelter at HF.
Last fall, I was concerned the small tares at the corners would lead to a major failure with the next big snow. The T@B had certainly earned it's place as a keeper in our life by then so..... I built a shelter on the side of our shed.
BTW - The portable garage sold "as is - you remove" on CraigsList for $80. It was gone in less than 24 hours after listing!! No regrets. It was a great solution for several years.
As for smaller rims, I think going smaller than 12" ones could cause some problems. You're getting into the garden tractor type now and I would have some concerns about weight distribution and such.
There may be other solutions, but I've never researched them. This is the second year I've used this method to bed Lil-Lucy down for the winter.
I will add that it gets a little tricky as far as the jacking sequence goes. Using my normal floor jack that I've had for years, when I set her back down on the 12" rims there isn't enough clearance to get the jack out. I took care of this problem by buying another floor jack with the lowest possible clearance. I believe it's somewhere around 3 1/2 inches. Then placing this jack towards the back of the frame, I'm able to get the bigger floor jack out.
I'll try letting some air out of the tires first.
Regarding a dolly -- If clearance isn't an issue but someone needs to maneuver a T@B in a tight garage space, consider these:
http://theautodolly.com/the-auto-dolly-line/the-auto-dolly/
