gulfarea said:A trick I would use would be to cut the old fuse out right close to the fuse leaving the old ends, then solder the new fuse ends to the old ones giving you more room to connect a heat sink while soldering. Then bend the extra wire to where it is not hitting anything. Thanks so much for bringing the answer to your problem to us. Another thing that might work would be to install an in line fuse holder with long wires to a more convenient place if it keeps going bad. Art
wizard1880 said:Hmm, that is unusual that those fuses would blow. They're probably non replaceable for a reason, kind of like a last resort on the board when something really goes wrong.
If it doesn't blow again for another year, you're probably OK, and it was just a fluke somewhere in the system hopefully. But if it goes again in short order, it's likely some other component like the blower fan, igniter, element relay(s), gas valve solenoid etc. is on the verge of failure, and it would need to be serviced by a trained Alde technician to identify and replace the faulty component.
You and I know how to solder, but we shouldn't expect everyone to, or be worried about carrying a soldering iron whenever you camp
), but I think this info is more for the person who feels comfortable taking the Alde apart and seeing these things first-hand.
ericnliz said:...
Curiosity question though...is that a burn on the corner of the plastic green fuse holder marked 'fuse 3.15amp?
Good eye, ericnliz.ChanW said:...
Yep, I'm a little clumsy with the soldering iron.
PXLated said:ChanW, know how you feel, I was the tester for the fridge :-(
That would be interesting. Can't check mine till April.ChanW said:Pretty lucky, I'll say. Hope it lasts!
I'd love to know if the newer Alde boiler has the same thermal cutoff installed, with the same temperature rating. The DF91S is rated at 91°C. I'd be curious if they perhaps changed it to one of a higher temp rating on later models.
