jkjenn
Member Posts: 6,417
I haven't changed it yet since it quit working. It went out in late February and I've been busy since then. I have the replacement USB, just not enough time right now.
I know the 12v items in the T@B will work when not connected to shore power (Jensen, fridge, etc). But... are the 12v outlets also live? Or do they go through the converter and are only live when plugged into shore power?
2018 T@B Max S silver and black (aka TadT@B), Full-timing since July 2017
I also went through my the diagram that Mike posted in another thread of the converter and wondered also found some threads where Mash2 tapped into the pump wires. I am so weeding is the fan wires might be a better choice. The pump can draw up to 5 amps and the fan, especially after my upgrade is about 1/2 of that. However, the fan will run more often.The lights share the fuse with all lughts, the tv, and Jensen.
All of these are running off 10 amp fuses.
Yes, that is what I was thinking - near the converter. I think it depends on which circuit powers those. I will dig out my little Fuse Buddy to figure that out. The Fuse Buddy was a good investment. The outlets I picket up are actually fast charging USB.
She needs a new wand.
I agree with Dale. I've done extensive tracing and diagrammig of the wiring and in fact, the 12V outlet wiring that's above the sink is in the light blue wire loop, which also has all the lights. On mine, it seems all the things in the ceiling share the same branch.
