Fantastic Fan Vent Opening Knob - Ouch
Has anyone found a smaller knob, or done any modification to make this knob more flush to the fan?  It's the most common place I've skinned my head,  and it really doesn't need to be that big of a knob.  If I lived in there full time,  I'd probably have the muscle memory to miss it,  but seems like I at least graze it once a trip.
I took the knob off, hoping I could fashion a smaller one, but it's integrated into the unit with a metal sleeve and the screw goes the entire length.
    edited April 2017
    I agree and have wondered the same thing. It really hurts!
    db_cooper & jkjenn, Wow, I'm tall, and haven't hit it yet..... Only thought I have right now would be a bright colored tennis ball with a slit cut in it to cover it and soften the blow & make 'ya more aware of it. Let's ask the mod gurus....dalehelman, any ideas, Pop-T@B..?
    I've never done that either.......;)
    My dad always told me being short would be rewarded - You bend down more than you reach up and you don't have to worry about pesky knobs :-)
  • rfuss928rfuss928 Member Posts: 1,083
    edited April 2017
    How about a vinyl cap like those used to protect pipe fittings before installation?   The right size would just slip on the outside surface of the handle and not really interfere with operation.
    These are about 1-1/2 to 2 inches in diameter and 3/4 deep soft vinyl.
    The 2" one fits my MaxFan pretty well.
    Almost every day. It seems to hit right at that softer, more vulnerable part of the head, too.
    The rubber caps wouldn't do it - needs to be thicker. I thought about using a thick batch of Sugru to make a ball around it but I am not sure that would do it. I also thought about one of Rocky's mini tennis balls.
    I doubt Fantastic Fan ever envisioned their product would go someplace with such low clearance.
  • hymiehymie Member Posts: 150
    Have you looked at the McMaster Carr catalogue? They have every profile / size ever made.
    James & Jacquie     Almonte, Ontario
    2016 Jeep Cherokee & 2017 T@B Outback
    @jkjenn,
    Soft head?
    Eh?  :open_mouth:
    (I guess yours just hasn't hardened up enough over the years, and developed calluses, from hitting your head too much.)
    edited April 2017
    Yup and 2 concussions....one that gave me headaches for a year. :(
  • db_cooperdb_cooper Member Posts: 739
    I also lack the stringy protein scalp protector, so every bump shows. ☺
    I think JKJenn and myself probably hit the knob more than tall folks because we're just tall enough to hit that thing but not used to having to worry about it anywhere else.
    I may have my tinkering neighbor give it a go, he just got a 3d printer. :)
    Problem solved, at least for me.  I removed the knob and screw.  You can just put the knob back sans screw, and adjust fan.  Remove knob and store someplace.  With the Outback cargo nets, I'll just throw it up there in a corner.   Cheapest mod to date. :)
    LOL db!
    Perfect, thanks. I have the remote so don't use that black handle, anyway.
  • NewfisherNewfisher Member Posts: 105
    Tennis ball? Like what Dad used to put on the trailer hitch to keep it from getting grease on his pant leg.
    1 inch of Velcro to secure knob on cargo shelf = .05 c
    Not bumping head on knob = Priceless
