Tried this week to use one of those magnetic strip propane gauge.  For me, they are a waste of money.  I couldn't see the gauge inside the propane compartment.  So, I purchased a screw on gauge from Walmart for $28.  Was very happy about this purchase until we went to Costco today.  They are selling tanks with a built in gauge for $25.  Hope someone can benefit from my mistake.
                0 ·
https://www.amazon.com/Products-024-1001-Propane-Level-Indicator/dp/B01C5RQJHS/ref=pd_sim_263_1?_encoding=UTF8&pd_rd_i=B01C5RQJHS&pd_rd_r=RE2T03JZGVXGB2JA8AKW&pd_rd_w=3egsm&pd_rd_wg=GKC6L&psc=1&refRID=RE2T03JZGVXGB2JA8AKW
A bit spendy at $40 but it sure seems accurate. Because it attaches to the tank with a magnet I can move it easily between tanks. The model we have uses bluetooth and an app on our iPhone. They have a model too that has a display you can mount in the camper.
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota
https://www.uhaul.com/MovingSupplies/Propane-Tanks-Heaters/U-S-20lb-Propane-Tank-With-Gas-Gauge?id=13318
I can't yet vouch for how well it works, but I learned about it on this board and those that have it spoke highly of it.
They work OK--just don't think that because you're in the green it will make it through the night. They're an estimation at best.
2014 T@B CS Maxx
Martha Lake, WA
There's composite tanks available which are translucent, allowing you to see the level of propane inside. They're awfully expensive unfortunately. But they save several pounds of tongue weight if that's a priority.
2014 T@B CS Maxx
Martha Lake, WA
https://www.amazon.com/Grill-Gauge-GG-1100-Original/dp/B0012GTU3O/ref=sr_1_4?ie=UTF8&qid=1493462241&sr=8-4&keywords=propane+tank+gauge&refinements=p_72:2661618011
2016 Max S
Kalamazoo Michigan
There are different manufacturer's of the OPD valves inside. Some overflow valves will allow 5 gallons of propane inside, some just 4.5. My "empty" tank took 3.5 gallons (4.2 lbs weight per gallon of propane). Before topping it off, it weighed 22#. So for my two tanks (manufactured at the same company and time), are full at 38 lbs. I also realized my regulator appears to be upside down, but I'm not sure. The dual tank switch points to the tank that is empty LOL. I repaired that by my trusty label maker! Also marked which tank was which.
I hate to say this, but the most accurate and quick way I can tell how much propane is left is the "hot water test". Pour a cup down the side of the tank and feel the side. When the area turns from hot to cold, that's where the propane level is. Add-on gauges are also highly dependent on temperature. They are notorious for leaking, and pressure is maintained in a tank unless it's totally purged. I love the concept of the composite tanks! Internal float tanks too. Too pricey considering I can weigh or do the hot water test.
This tank is 8.2 kg (18 pounds)
I have this and am very pleased with the accuracy. Since I know ABOUT when I'll get low, I'll use it and when I take the tank to be filled, the outcome pretty much matches what this gauge indicated. At first I wasn't sure I'd be able to handle getting the tank in/out (being short and not strong) but I stand on the tongue and am able to get it in and out fairly easily!
I totally love this concept too. When it gets into the yellow, does that indicate a percentage mark (like math involved) or is there an approximate gallon amount left?
On mine, when the needle is in the middle of the yellow, the tank is half empty. I tracked this on a recent trip.
https://www.amazon.com/Dometic-LPGC10-LP-Gas-Checker/dp/B00Q7379X0/ref=sr_1_1?s=hi&ie=UTF8&qid=1502541447&sr=8-1&keywords=lp+gas+checker
http://www.levelcheck.com/us/
Most of the aforementioned gauges are based on pressure, which varies a lot with temperature. Here in the West it can be 32deg in the morning (gauge reads empty), and 70deg in the later afternoon (gauge full). It's a pain, but I've been taking the tank out and weighing it (17# empty, 37# full), every month or so...so a nice compromise would be one of these ultrasonic jobs. I've read about the ones that mount to the bottom of the tank, then read out via Bluetooth to a device or your phone, but they all seem to have a number of bugs (and they're pricey).
J.D. & Sue
Both my Tab tank and my spare have a center weld...
Edit: I see in the 'Questions' area:
I checked with the brand name and features on the web for the 2 tanks I have to validate that those tanks did have the internal float.
Utah Driven
2019 T@B 400 (Ex 2018 400)
2015 MB GLK 250 Diesel
2018 GMC Canyon Denali Duramax CCSB
