Inside kitchen sink awkward for use?
I am 5' 9" and concerned about the awkwardness of using the inside sink with the overhead cabinet. In trying it out at the dealer it seemed to require a very uncomfortable position to use it while standing- any input would be really helpful.
  • RoameyRoamey Member Posts: 239
    Hi,
      We recently picked up our T@B S and had to leave right away for our planned vacation, so are getting used to it as we go.  I am a hair taller and haven't used the sink yet, but after seeing your concern I tried it. I agree it is very uncomfortable with the cabinets in the way. Also check out the threads on the refrigerator before making a decision. We are finding it doesn't work. It won't charge off the car while driving and the propane apparently blows out while driving. When we stop and check it, the food temperature is in the 50's. It seems there is no fix. The camper doesn't do us much good without a refrigerator.
       T@B trip wherever
    New surprises everyday
       See beautiful world
  • cbarnhillcbarnhill Member Posts: 330
    Roamey: about the fridge: it's not a good idea to power your fridge with propane while driving. The movement of the rig will knock it out and you'll hear the ticking of the propane trying to recharge it. i recommend cooling it before you leave and either using it like a cooler and just shut the door (short trip only) or put it in battery mode. If your TV isn't charging your battery while driving, that's sounds like your 7-pin hookup isn't working properly.
    Cindy with my 2015 MaxS (Puppy) and my 2015 Subaru Outback (Boo)
  • mandtmandt Member Posts: 158
    Yes the sink is awkward, I agree. However we still like the trailer and work around it.
    Mickey & Terri
    2016 Max S
    Kalamazoo Michigan
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,023
    Cbarnhill, the 3 way frig while on battery is not thermostatically regulated and results in draining the Tab battery and the heavy draw on the inadequate output from the TV battery results in a warm frig.  Best advice, as you said, is to pre-chill and use it as a cooler with frozen milk jugs.
    Cbarnhill. Thanks for the input. This 2018 has a manual ignitor on the refrigerator control panel that we have to hold in while lighting it. Maybe that is their "fix" for the problem of going off while driving?  Doesn't address the real issue.
       T@B trip wherever
       See beautiful world
    edited June 2017
    If the 7 pin connector has been wired for 12v and your car's alternator is beefy enough the fridge should stay cold while traveling. I'm sure someone will chime in about using propane, but all the authoritative sources I've read say to use the fridge in 12v mode while traveling.
    As as for the sink, at 5'7" it works fine for me. if I were taller I'd kneel on a short step to use the sink.
  • Smullis7Smullis7 Member Posts: 221
    My 6'2" husband kneels when using the sink to wash dishes, and it is awkward for him...not sure there is any way around that due to the cabinets and slope of the wall.  As for the fridge, I tow with a 2016 Jeep Wrangler Unlimited and have no issues keeping the fridge on 12v with the 7-pin.  I do turn the temp down...not sure that actually saves much juice, but logic says it should.
    I have seen some owners use the collapsible dish pans outside the TaB to get around the comfort issue while doing dishes at the sink.
    A suggestion: an inexpensive folding bar stool from Amazon. Fold out and sit to wash dishes, fold up when not in use.
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,337
    I'm  5 9, and, yes, it is a bit cramped....but when I camp I don't plan to work at a sink for much more than a minute or so at a time.   If I had to do more than that, I would think I was "camping" wrong.
    My Touareg handles the fridge just fine on 12V while on the road.
  • NatalieC_NatalieC_ Member Posts: 6
    Thanks for your input everyone! very helpful...we actually just bought the T@g Outback today....picking it up next week! Which leads me to my next question, however I will take it over to the T@g area....
    natalie
  • Rolltide82Rolltide82 Member Posts: 89
    I always wash dishes outside.....just feel more outdoorsy lol
    In terms of fridge on battery while driving, you won't notice the battery drain until you are driving pretty much full days. When I put in 10-12 hour days, I try to alternate every few hours between on and off, to keep things cold and keep the battery charged. It wouldn't be very noticeable of a drain in less then 4 hours.
  • AldebaranJillAldebaranJill Member Posts: 478
    This depends on your tow vehicle. I've measured mine by zeroing out my meter, turning fridge on 12V, and driving. Each hour I drive I lose 3 AH. After 4 hours, that's 12 AH, which would be a very significant loss if you're boondocking.
    @AldebaranJill, I luv peeps who take the time to stop and measure. Did you do a spreadsheet too? More T@B University brownie points for that!! :lol:
    LOL - Yup, I figure too much hypothetical over generalizing misinformation on the interwebs already, I don't need to add to it. Just real data :)
    I did not make a spreadsheet for this but will try better next time. More brownie points please!
  • Sam_in_VASam_in_VA Member Posts: 6
    I'm 6' and have a tripod hiking stool that i sit on while cooking and doing dishes inside.  It's ~15" tall and takes up very little room in use or in storage.  Its not a perfect solution, but it certainly makes it better.  It's also useful as a spare seat outside.
  • lapowers57lapowers57 Member Posts: 186
    At 6'1"  the kitchen sink is awkward to use.  I am the dishwasher and will wash at the picnic table or at the cleaning station if the campground has one.  This also minimizes water in the grey water tank.  And working at the cleaning station is a good way to meet people.
    Same for the stove.  I am the grillman so I do most of my cooking outside.  If I have to work at the stove I sit on the end of the settee.
    My wife at 5'7" does not problem with the sink or stove.
    I like the idea of the stool but it would be one more thing to carry so it would need to have additional uses to be worth while.
