Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
Front Window installation
driftless
Member Posts: 135
Has anyone seen installation instructions for the opening front window. Just received the new window today didn't see instructions. I have an email into Elsie about this.
Happy Trails,
Phil & Anita - Driftless: 2018 T@B 400/2015 Ford Explorer
That's an Elsie question. We have no instructions for that.Verna, Columbus, IN
Thanks @Verna, we will wait on a response from Elsie.Happy Trails,
Elsie is the best! I ordered another front window, too, but decided to tape the crack till the end of the season. Elsie told me it was very simple. Carefully remove the 4 handles. There should be 4 screws holding the window on. Unscrew these, remove window, replace with new window and reverse the process to install it. Never hurts to get it straight from the source, though. Let me know if I'm wrong.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red -
It's a bit of a procedure for the front window, but it's basically the opposite of removing the old window. I was able to do it solo, standing on the Outback cargo rack, but it would be much easier with two people.
First remove the screws holding the two window supports from the window.
To remove the window you will be sliding it out of the track sideways. It is easy to scratch the paint, so it you have to be steady. You can only slide it to the right, the trim of the T@b will interfere to the left.
There is a set screw holding the metal rail in place, so remove that. You have to open the window up very high to see the set screw, and also to slide it out to the side. The metal bar will come out with the window, and will fall out when you get the window 3/4 out, so have the second person ready to grab that. Then have them help you finish sliding the window out.
The hardest part for me was getting the new window started in the track and keeping the metal bar from falling. It's hard to see what you're doing, and holding the window high is tiring, especially since you're trying not to ding the camper. If you don't get it the first time, take a break.2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620 -
@driftless, I changed the category on this post due to @db_cooper giving such detailed instructions. I think we have instructions now! Thanks @db_cooper!Verna, Columbus, IN
Although @db_cooper instruction were great we were looking for info on replacing a non-opening front window with an opening one. That being said tackled the project today. Pretty straight forward by looking at how the side window is installed.
Happy Trails,
Nice job. Looks original. You will appreciate the ventilation.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
This is something I would like to do next year.
How much did the replacement window (that opens) cost?
@lauriehart, the cost of the window was $260 plus shipping. We ordered it on the Nucamp store website.Happy Trails,
If moving from a permanently closed window, ypu will need to plan for a new day/night shade, too.driftless said:@lauriehart, the cost of the window was $260 plus shipping. We ordered it on the Nucamp store website.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
@lauriehart the shade assembly cost was $163.Happy Trails,
Niiiice!!!Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
My front window nearly fell out when I went to open it. I can't seem to figure out what's missing to hold it into the track. Is there a pic somewhere? I'm trying to see if I can simply replace the missing part, not the whole window assembly. Has anyone done this? Maybe a modification? TIA
2018 T@B 320S / 2024 Chevy Blazer RS AWD / Phoenix, AZ -
@ReenieG - check this thread: https://tab-rv.vanillacommunity.com/discussion/comment/173522#Comment_173522Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
EDIT: I'm understanding more about the window assembly now and I see the "metal rail" is the aluminum rail that the top hinge of the window is seated in.@Sharon_is_SAM thank you for the link, however, I still can't make out what is missing on my window. It seems there's a metal bar from what @db_cooper is saying above, "There is a set screw holding the metal rail in place, so remove that. You have to open the window up very high to see the set screw, and also to slide it out to the side. The metal bar will come out with the window, and will fall out when you get the window 3/4 out, so have the second person ready to grab that. Then have them help you finish sliding the window out."I see the screw, I see the window, but I don't see any "metal rail" that can fall out, so I'm thinking my "metal rail" is missing and want to see what it looks like to see if I can fabricate something vs buying a whole new window assembly!
- 916 Introductions
- 72 Teardrop Groups & Links
- 913 Tips & Tricks
