Third day on a road trip, another issue just appeared. We have a 2015 S Max with the yellow Alde relief valve located the last thing before the cold water line goes into the Alde. We are using the T@B's water tank as our water source. The setting for the Alde was for hot water only, being heated by shore power, not propane. My wife just drew some cold water from the kitchen sink, the water pump turned on, and immediately the pressure relief valve starts intermittently going off and spitting water out on the ground. When I flip the valve to straight up and down, a steady stream of water spills out. When we turn off the water pump, it stops for the moment but begins again when we flip on the water pump switch. What's going on?
2015 T@B 320 S, 2019 Jeep Cherokee
0 ·
Anyone else have thoughts?
My big camper propane HW heater needs an air cushion as well, but the instructions say "there's an optimal amount of cushion that it needs" wha? Oh well. If I have issues, there's a valve on the HW heater that'll start spewing too!
Keep us posted if things continue to go well and that was the ultimate fix!!
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
