We have ordered the Tab 320 CS-S. It will arrive with the outback front hitch equipment, carrier and additional storage options as well as the battery and Propane cover. I want to install a weight distribution and anti sway device on the hitch. I have ordered the Fastway e2 unit. It is the smallest one I could find but after pulling a similar trailer across Texas last weekend, I know I need some assistance with these units in heavy wind and big truck traffic. Does anyone have any suggestions on set up and operational usage with these units. I have been pulling for decades, but never used one of these units. Thanks in advance.
WrongWayRex
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
Our TV is currently a 2016 JK Jeep two door, automatic with V6 and 4:11 gears. We are pulling a TAG Max right now and waiting for the new trailer to be delivered in a few weeks.
Central Alabama
Alan & Patty
Southern Az
Now that I've added weight to the tongue with 6v GC batteries and moving the spare up front I might not need the sway bar at all. Something to think about if you are going to add weight to the tongue.
2022 Ford F350 Tremor | 2022 Cirrus 620
Central Alabama
2019 Ford F-150 3.5L Ecoboost with Long Bed
and it is not every body who know how to quickly react if something happen when cruise control is on, and I am not just talking about what is in front of you, but also lost of control du to anything. So adding a trailer to cruise cntrole, not a good idea. People become to relax and off guard.
not a good idea with a trailer, no matter what towing capacity you have.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
As per pthomas745's post, I agree that the use of cruise control will cause no harm to a vehicle that is otherwise adequately equipped to tow the load.
I also agree with Luckyj that anything that removes the driver from direct control of the vehicle will likely slow response time in the event of an emergency. How much is matter of debate. Checking your phone, fiddling with your radio, or arguing with your companion over directions probably make you far more of a road hazard than towing with cruise control.
Of course, nobody here does any of those things, right? ;-)
When I picked up my T@B and it was empty, it shocked me how much it bounced around and jerked, more than anything I've ever towed. It really settled down once I "moved in" even though I am a minimalist and tend to keep weight to a minimum.
That being said, I have considered adding a small anti-sway friction bar, you can find them for around $50 on eTrailer. I know that a weight distribution setup is not recommended for a T@B. I've always felt safe, but I hear you about crossing Texas! When I went through there I think the speed limit in some places was 80MPH and those trucks do whip around you. I never felt out of control, but I thought it might be worth the relatively small investment for some piece of mind.
@WrongWayRex the best of luck whatever you decide, and please let us know what setup you go with and how it works for you!
2018 T@B Max S silver and black (aka TadT@B), Full-timing since July 2017
the thing I have about using cruise controle while towing, no mather if your TV can do it or not, is that some people do not know how to quickly react in en emergency situation, and adding a trailer is adding one major thing that will make a TV react in totaly different way in an emergency situation. It can even create the situation.
but hey, we all know someone who text and faceplook while driving, that says he or she can do it and still be safe.
