Solar monitor location
I'm in process of installing a solar unit on my T@B. The panel is mounted on the rear Yakima rack of the camper. I'm curious where everyone is mounting their monitor/controller. Has anyone put it in the tongue box with the battery? Any problem with running the wiring underneath the camper up to the battery box?
Stancil Campbell
2011 T@B
Rockingham, NC
  • Verna
    Verna Member Posts: 6,876
    @Estancio, if you do a search for lunch box, you find some interesting ideas of how other owners placed their solar controllers inside lunch boxes inside their front tub.
  • Michigan_Mike
    Ideally you want the solar controller as close to the panel as possible as you will have some voltage drop if it's further away.  There are formulas out there to determine voltage drop, optimizing the panels solar gathering capability, etc.  If it were me, I'd mount it on the side wall or at least keep it inside the trailer.  You could probably mount it inside the tub, but am sure there are some mathmeticians here on the forum who will be able to provide you with more precise data if you post up your panel specs and the size of your solar controller.
  • jkjenn
    jkjenn Member Posts: 6,425
    I mounted mine inside and used 8# wire to compensate. It is very efficient, but what a pain in the neck to work with. 10# is much more mangable.
  • Estancio
    Estancio Member Posts: 243
    My solar kit from Renogy came with all the wiring -- a run from panel to controller and a run from controller to battery. I am assuming their engineers have already looked at how long the run could be and packaged the wiring accordingly.
    Stancil Campbell
    2011 T@B
    Rockingham, NC
  • Estancio
    @Verna, my tongue box is not the T@B original, but a water tight aluminum box. I do not think I would need any further protection such as a lunch box.
    Stancil Campbell
    2011 T@B
    Rockingham, NC
    ScottG Administrator Posts: 5,693
    edited March 2018
    I think the conventional wisdom is to have the controller as close to the battery as possible. In good sun, there's usually some excess voltage coming off the panel that you can afford to lose a little from voltage drop. However, the voltage coming from the controller has been optimized for charging--any drop that occurs between the controller and the battery will reduce your charging potential.
  • drazilgod
    drazilgod Member Posts: 11
    edited March 2018
    I have thought about roof mount solar panels, running wires under that fat curved side/roof trim. But for now we use a solar suitcase, 50 foot of 14 gauge cord, and controller velcroed to the inside lid of the tongue box. Never had an issue. I agree with ScottG, the output side of the controller is usually much more affected by voltage drop, put the controller close to the battery. I wouldn't worry too much about the voltage drop on the input side of the controller (from solar panel to controller), at least for the distance you and I would be running.
  • Estancio
    @ScottG, yes the installation instructions said to keep the controller close to the battery. That's why I considered inside the tongue box. The 20-foot run of wiring that Renogy provided is exactly the length that I need to get therefrom the Yakima rack. Ordered two 30amp circuit breakers today that go inline with the wiring. All is falling into place!
    Stancil Campbell
    2011 T@B
    Rockingham, NC
  • CincyKid
    CincyKid Member Posts: 83
    So, as a newbie to solar.  From the dialog above it appears I will need a separate controller in between the panel and the battery?  (that is the trailer's controller will not have anything to do with the solar power into the system)?
    CincyKid
    Cincinnati, OH
  • dlud
    dlud Member Posts: 32
    CincyKid: yes that is correct: you need a separate solar controller. The trailer's controller does not come into play.
  • ChrisandAlexis
    ChrisandAlexis Member Posts: 120
    @CincyKid, yes, that is correct. The separate controller that sits between the solar panel and battery is used to regulate the voltage coming out of the solar panel and has nothing to do with the T@B controller.
    Chris and Alexis-- Roseville, California--2017 T@B CS-S--Toyota 4Runner
  • CincyKid
    Thanks to dlud and ChrisandAlexis for your answers, thinking to mount the controller inside the propane tank area of my boondock.  Found a $25 controller good to 25 watts at Freight Harbor (where I bought the 15 watt solar panel on sale).
    CincyKid
    Cincinnati, OH
    Looks professionally installed!  We have fuses in our system.  Why the circuit breakers?
  • Ratkity
    Ratkity Member Posts: 3,770
    Wow! It does look like a nice clean install done by a pro! I won't show you my lunchbox controller setup lol. Looks like a science fair project... from an elementary school kid. :lol:
  • jkjenn
    Great work!!
  • ericnliz
    ericnliz Member Posts: 4,437
    Nicely done! Now you can do LOTS more boondockin'! B)
  • Estancio
    @SAM, the circuit breakers function well as switches. Easy on and off. For me if was worth the expense over fuses. My T@B came before they added battery disconnects, so having 3 separate switches gives me lots of options for isolating components.
    Stancil Campbell
    2011 T@B
    Rockingham, NC
    I see.  So the circuit breaker between the battery and camper is your battery disconnect switch.
    edited May 2018
    Good looking install. Just keep in mind that the fusing of the system is in part to protect the charge controller, so the fuses/breakers should be sized based on its specifications. For example, my 100W suitcases uses a 10A rated controller, so a 10A fuse is installed between the controller and the battery.
    Therefore, if your controller isn't rated for 30A, you might want to incorporate some additional protection.
    At least that's my understanding based on limited solar experience. If I'm wrong here, someone please correct!
  • Estancio
    @ScottG, the instructions with my Renogy system was very specific for 30amp protection between the panel and controller, and between the controller and battery. The T@B came from the factory with a 30amp fuse between the battery and the camper. So all is correct according to information I have available.
    Stancil Campbell
    2011 T@B
    Rockingham, NC
  • CincyKid
    That install really does look great.
    CincyKid
    Cincinnati, OH
  • ChrisK
    ChrisK Member Posts: 281
    I’m getting together my stuff to install solar. I have the Victron controller and the instruction say to mount it in an area that is within 5 degrees of ambient from the battery or it can overcharge the battery. I guess it senses temperature of the controller and adjusts charge rate based on that. They offer a dongle to mount to the battery if you mount your controller elsewhere but I can’t find it available anywhere. I guess it sends voltage and temp info to the controller wirelessly. I wanted to mount the controller inside out of the heat.
    2014 T@b S Max AKA T@dpole
  • jkjenn
    ChrisK said:
    I’m getting togther my stuff to install solar. I have the Victron controller and the instruction say to mount it in an area that is within 5 degrees of ambient from the battery or it can overcharge the battery. I guess it senses temperature of the controller and adjusts charge rate based on that. They offer a dongle to mount to the battery if you mount your controller elsewhere but I can’t find it available anywhere. I guess it sends voltage and temp info to the controller wirelessly. I wanted to mount the controller inside out of the heat.
    If you contact them, they are great about answering questions.
  • ColoradoJon
    ColoradoJon Member Posts: 415
    @chrisk - Unless you have a specific reason I would simply mount the controller near the battery like Estancio did.  The controller is temperature compensating, which is awesome, but you don't need to monitor the controller constantly so having it somewhere out of the way is not a problem.  In colder weather the controller will increase the charge voltage to the batteries, and reduce the voltage in hotter temps.
  • ChrisK
    Yeah, that's probably what I'll do. I was wary of putting it there because of the AZ heat. It is the bluetooth model so I don't have to worry about running the wiring for the external monitor.
  • dsatwork
    dsatwork Member Posts: 744
    Just getting caught up on the forum and saw this installation....very nice job.
