Dalehelman: I've read that it is easy to blow by the inner sale and mess up the brakes. Have you tried this proceedure by Dexter? I've only done bearings the old fashion way with the palm of my hand.
Yep, Ron I am guilty of blowing out a seal. Despite my best efforts. Thankfully I have a habit of feeling my bearings when traveling and no harm was done because when the blown out side felt hot I had it looked into. Now I am very reluctant to grease hem myself.
IMHO You have two choices. You can do it yourself or you can allow someone else. Since it is about a 1 on a scale of 1-5. These jobs are generally given to less skilled service people generally with an air powered grease gun. If you are not comfortable with this procedure by all means hire it done.
@Dalehelman, only the head mechanic is allowed to pack and grease wheel bearings at the utility trailer business I take my T@B to. They value their reputation and they intend to keep it. So, if you find a business like this, keep it, and recommend it to your friends.
If you’re around Whiteland, Indiana, Mayes Trailer Sales is the place to go if you’re like me and you’re not a mechanic.
Verna, Columbus, IN 2021 T@B 320S Boondock “The T@B” Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”
That’s a very impressive service standard. It pays to research your service provider.
I am learning new things on this forum everyday. I feel bad for T@Bers that haven’t found it or take advantage of its members vast knowledge and friendly spirit.
Fortunately, I have a similar situation. The shop I take mine to has been in business for 30+ years, and it is owner-operated. If you are going to have someone else do your bearings, in my opinion, this is the best situation.
2022 T@B 400 BD 2019 Ford F-150 3.5L Ecoboost with Long Bed
I vaguely recall a minimum spec provided in the owner's manual for the axle assembly, but I don't think it's anything special. As Dale suggested, any grease intended for the purpose should meet those specs.
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
I watched the video before my 6,000 mi. trip back in sept.. I used Mobil 1 Synthetic Grease... went Dexter`s website Called nucamp also use Lithium complex grease only... Used about a whole tub of grease for both bearings...
In the video narration, you mentioned that they come from the factory with very little grease in them. I'm wondering why? We took delivery of our 2018 320S in January and have four outings under our belts, the last one for about two weeks. We probably have 2000-2500 miles on the T@B.
We’re we took our T@B in for state inspection a couple weeks ago I had them repack the bearings. The guy asked if we’d been greasing them and we had to say no, we didn’t know how.
It it would be awesome if there was a demonstration of this procedure at uCamp!
@Photomom, it depends on how much grease was in there to start with. The video says that they come from the factory with not much grease. The bearings fill from back to front, so, once you no longer see old grease, then the bearing is full of new grease. The most difficult part of this job was the tip of our cheap grease gun kept getting stuck on the end of the Zerk fitting!
