I am in the process of getting ready for my first extended trip- - -from Virginia to Nova Scotia. I am trying to do my due diligence and grease my axles. I greased the right one just fine. When I popped off the cap to the left axle, this is what I found. The wire and blue metal showing is something the right axle didn't have and I'm wondering if something is seriously wrong. Any ideas folks?
I apologize if the photo is too large (I'm suspecting it is). I'll work on resizing, but for now I'm a bit concerned and going for speed. Thanks for all opinions!
If you can clean the grease off and post another pic it may be easier to tell, but from what I can see you should not tow it anywhere.
Edit: As opposed to a bearing, it looks like it may be a seal, but the bigger issue is the potential broken spindle nut.
Interestingly, I have driven 500 miles (though it was last year) with the Tab, and I'm assuming it looked like this all along. I'm hoping it is okay to drive to an RV service center (about 25 miles from me). If you can't tow a trailer, how do you get it somewhere?
TV: 2012 Honda Ridgeline
Alice
Crozet, VA
Alice
Crozet, VA
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Alice
Crozet, VA
If you can pull out the rounded piece that is sitting below the nut (use a pair of needle nosed pliers) clean it off and post a picture it would be very helpful. Also please clean off the rest of the loose grease and retake your picture so that we can help you to diagnose the (possible) failure. With the grease in place even with the picture zoomed up to it's largest size it's hard to be 100% certain of what is happening there.
If there is a bearing problem replacing it is not very difficult. You'll simply remove the cotter pin from the nut, spin the nut loose and start disassembling things. Anyone who is reasonably handy with cars and has done brake and bearing jobs can muddle through with minimal effort. The critical piece is to re-tighten everything correctly..not too tight, not too loose...
If there is a bearing issue the axle should be inspected for wear once everything is pulled apart.
The concern is why would the cotter pin (if that is what we see) is not in place in the nut? And if the pin is not locking the nut, has the nut spun? If the nut is not correctly tightened you could loose the pre-load on your bearing races. That could damage the bearing and the axle....that blue material could be the inner seal from your bearing...
If you are not capable of doing the repair yourself, trailering is the safe way to get it to a shop...don't tow it.
You should re-check the other wheel that you have already greased and make sure that the castle nut is correctly seated...not too tight, not too loose.....remove the cotter pin to check it. Tighten the nut to the point where the wheel starts to bind and then back it off just enough to get the pin through. If the wheel then turns nicely you are done. Bend the cotter pin in place before closing everything back up.
Please be very careful about how you jack the trailer up while you are working on it. You don't want this rascal dropping on your feet.
If this can help. What I do see when I zoom in your pic, is a very long cutter pin that was pulled back over the spindle (shaft where the nut is tighten over) and just behind, I see the castle nut head. But what is weird, is that when I look at ezlube spindle on the web, the castle nut is non existent, they use a standard nut with a locking plate.
http://pic20.picturetrail.com/VOL166/13567593/24380256/407412418.jpg
cutter pin look twist over like the one.
http://http//pic20.picturetrail.com/VOL166/13567593/24380256/407412418.jpg
and this is typicaly how the e z lube spindle and hub should look like.
I would pull that wheel off and and see exactly what you have.
This is what should be on the end of that axle shaft:
https://www.etrailer.com/Accessories-and-Parts/Redline/RG05-100.html
I don't think you have a problem, but you might not have the EZ Lube axles or it has been modified by someone. If that's the case you need to re-pack the bearings manually or pay someone to do it.
Alice
Crozet, VA
Alice
Crozet, VA
anybody else here has a the same trailer and know about the type of spindles on the axle of such a trailer. Should they have a e z lube axle?
and like atlasb said, I would have it looked at, but if whell is solid and spinning free w/o grinding, I would not ne to worry about it to get to your mechanic. A nearing unit is a simple machine with straight foward engeneering.
The other axle did not have a cotter pin showing, which is what created the angst in me. I figured something was out of alignment. I think I will be cautious and have a mechanic check it out. I do feel much better about towing it though. Thank you so much for all who took the time to do research and weigh-in on my question. This is truly a great community.
Alice
Crozet, VA
I'll have another look in the near future and post back if I have anything substantive to add.
Alan & Patty
Southern Az
Alice
Crozet, VA
Anyway, yeah... you really can't see the axle nut in that shot. On mine the axle has a flat spot that the retaining washer keys on ( D shaped). The retaining washer then clips over the axle nut corners and locks it onto the axle.
Alice
Crozet, VA
