RV Lock Keyless for RV's is great! (Currently for T@B S Max and T@B 320 {pre 2020} only)
Silly question, the Memorial Day sale is on at RVLock so I want to get the lock for my 2018 320 CS-S. Do I need the right or left and does it have to be the v4 or will the compact one work. They don't seem to be much different other than shape.
Aileen, Muggles & Scout @ 2018 T@b CS-S @ 2018 RAV4 Adventure @ Massachusetts0 -
I have a 2013 T@B CS-S and here’s what I bought and installed:
RVLock Compact Keyless Entry System W/ Integrated Keypad × 1
Right Hand (right side hinged)San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
Mr. Homebody and I just installed the new lock the other night. Yes, it took longer than the reported 10 minute install, but the directions were clear and I'm satisfied. Oh, and yes the beep is loud. I might work on that...2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1
@Homebodyatheart, the beep can be turned off. I think the info is earlier in this thread. (You end up with no sound at all, however, but we got used to it)
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
Holding down the "1" button until you hear a tone toggles the sound on and off. As @ChanW said, when sound is off it is completely silent. I wish there was a way to just turn the volume down (not off).
Downers Grove, IL
2017 T@B 320S Max, Blue and Silver -- "The Blueb@rry"0 -
Thank you @ChanW and @FishDoctor! I will try it this weekend. My first inclination was to remove the inside pkate and see if I could cover/mute wherever the sound comes out with something. I’m fine with no sound.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
So for anyone else who wants this lock what I went for is the
RVLock Compact Keyless Entry System W/ Integrated Keypad, Right Hand (right side hinged). It went in easily and it looks similar to the one that was there previously. It works great. I did watch a number of youtube install videos before I did it just to see what the mistakes were and that made it easy.
Aileen, Muggles & Scout @ 2018 T@b CS-S @ 2018 RAV4 Adventure @ Massachusetts2 -
@geekmama the only tight fit was pushing the front plate and latch in place. I didn’t want to have to cut the Azdell, but really had to push hard to get it in the space. Once in it fit perfectly!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
Just got an email from them-RVLock is having a Fathers Day 15% off sale this week.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
Will these work on the 2015 DM CS?0
Welcome to the forum @Anjenewell! A small point-Your 2015 was built by Pleasant Vallley, now known as nüCamp and marketed by Little Guy, not Dutchman. @Tabster and @Marceline have clamshells, perhaps they’ll confirm it works for them. Glad you’re here!John, Judi, Guinness & OD in PDX
I want one of these so bad!! *sigh*2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)1
I installed this unit in my 2013 CS.jgram2 said:Welcome to the forum @Anjenewell! A small point-Your 2015 was built by Pleasant Vallley, now known as nüCamp and marketed by Little Guy, not Dutchman. @Tabster and @Marceline have clamshells, perhaps they’ll confirm it works for them. Glad you’re here!
https://www.rvlock.com/collections/frontpage/products/rvlock-v4mini-right-hand-w-integrated-keypad-for-rvs
It wasn’t very hard. There was just a small amount of swearing as I worked to get the inside and outside pieces lined up correctly. It might’ve been helpful to have an extra pair of hands.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
2 -
Here's a little tip for those who don't wish to carry numbers of big thick keys in their pocket....
You can grind the plastic off the RVLock key, and there's a tiny key with a hole under all that plastic...
For me, that's perfect, since I'll seldom be using the key - only for 'emergency'.Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya2 -
I actually mis-typed. I have a 2005 Dutchmen CS.jgram2 said:Welcome to the forum @Anjenewell! A small point-Your 2015 was built by Pleasant Vallley, now known as nüCamp and marketed by Little Guy, not Dutchman. @Tabster and @Marceline have clamshells, perhaps they’ll confirm it works for them. Glad you’re here!
wondering if these keyless locks will work on the older models.0 -
That is the truth. I bought 2 outside storage bay doors to be installed in my T@B years ago. I got each of them from a different source, and the key is the same, AND is the same as my clamshell hatch keys. It's nice for me, but how many other hatches have the same key.....TabberJohn said:Storage bay locks are supposed to be even worse offenders of the same key.
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL0 -
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 6203 -
Mousie.. ALL, the dreaded C157 (or 751?) key. My toy hauler has a one-key system. The key for the front door also opens the hatches.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)1
I had a little trouble with my RVLock. Half the time it wouldn't lock or unlock the deadbolt even though I could hear the mechanism working. I called RVLock and spoke with Tasha who was great. She had me remove the inside plate and loosen a screw down near the red handle for the deadbolt. Then loosen the 4 screws holding in the plate. She walked me through every step. Things worked again well. I found that they did not have my Order Number in their system so I have no warrantee with them. But she helped me anyway. I got the RVLock on Amazon for a few dollars cheaper so now will wait to hear from Amazon about the warrantee. I just got the lock in Feb. and really have loved it. By the way Homebodyatheart showed me that to get rid of the annoying beep when locking or unlocking, just hold in the #1 button until it beeps. This will deactivate or active the irritating loud beep but you can still hear the mechanism working. Thanks so much. Learning so much with this Forum. I really have appreciated it. Bill@ndRox '18T@b Outback.2
Quick questions for all those who installed the RV Lock. I bought one directly from the manufacturer and had it installed on my T@B. Works great with locking, beeps etc. Only problem is that when I am inside, it takes a lot of effort and attempts to slam door shut. I have to really slam it so that the momentum allows me to turn the red lock.
Essentially, I am concerned that I am missing something that may be wrong and that the door need not be slammed to be shut.2016 T@B Max-s Outback aka T@B C@b@n@;TV 2015 Toyota Highlander Limited aka UmatreeNiki1 -
@Niki_Pur, Check ALL the screws for both the lock & the jamb. From time to time, I have to tighten mine because road vibration (my guess) loosens them. I usually take the time to tighten all the screws associated with the door & the jamb. Just need to make sure they're good & snug...be careful not to over-tighten & strip the screws.2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf2 -
@Niki_Pur, our Tab door has always needed more of a slam to close. It took a few months to get used to it, but now it's 'normal procedure' for us (even if we do wake the neighbors!)
Have to agree with @ericnliz about checking those screws though. They've been known to cause the door to jam shut at the most inopportune times, if they're loose enough!
After you've got the latch working correctly, and the way you want it to, a drop of low-strength LocTite on each screw will prevent further loose-screw worries.Chan - near Buffalo NY
Mine is a little stubborn too. I've considered pulling the screws out and working on the alignment but I haven't bothered yet. I've found that instead of slamming it I can usually just pull and hold it closed while engaging the red latch. But maybe it's not as bad as yours.Niki_Pur said:San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
@Marceline- my door is pretty stubborn. I have tried engaging the red latch while pulling door but that does not work. I am worried I will break the inner black handle with the pulling. Sadly, slamming seems to have worked best. Can't wait to try @ericnliz and @ChanW's suggestions.
2016 T@B Max-s Outback aka T@B C@b@n@;TV 2015 Toyota Highlander Limited aka UmatreeNiki0 -
Humidity, which currently abounds, here in the Burgh, makes mine a little tougher to shut.
I miss mine! As soon as I get on the road, I’ll start calling RVLock to get one in the works for the 400.Verna, Columbus, IN
Thanks @jkjenn. Had not thought about that. I had no problems earlier in the year (before RVLock) so assumed it was the lock, but it may be the humidity.
@Verna - I can imagine how much you miss it. After the Enduro mover, the RVLock was my best addition.2016 T@B Max-s Outback aka T@B C@b@n@;TV 2015 Toyota Highlander Limited aka UmatreeNiki0 -
My 2 cents. Our T@Bs are very large aluminum structured Fiberglas skinned heat sinks subject to extreme levels of expansion and contraction. It probably doesn’t take too much temperature to rack the door frames out of alignment.‘18 Tab 320S- mfg’d 4/17, acquired 9/17
Huntington LI1
