I would like to purchase a pair if they will work on the 400 but I won't be attending the Ucamp rally .
UCamp 18 rally ( replace your rear stabilizers with true scissor levelers)
@Dalehelman did this mod for me and I love it! The Tab actually feels less bouncy with them, and three point leveling is a breeze! It’s also quick and easy to put them down and up with my cordless drill.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red2 -
@Homebodyatheart
Thanks for the review. I don’t do this for the profit just my time, wear and tear and materials.- Hash T@B Fun
2 -
Dale, I might take you up on this one. I will let you know.
I guess this would also provide built-in jacks for changing tires or wheel maintenance, plus avoid the guessing game of where to put a jack.
Wish I was gonna be there.-Brian in Chester, Virginia
@BrianZ
The factory stabilizers can be used for tire and wheel servicing. It has been discussed at great length in many threads. Basically chock wheels. Unhitch trailer. Lower tongue as low as possible with tongue jack. Extend rear stabilizers all the way to the ground. Then raise tongue till tires leave the ground. This provides a very stable three point platform to work from. Each stabilizer is rated at 1000lbs plus the tongue jack which is 2000 lbs.- Hash T@B Fun
Yep, I think I've read them all. But you wouldn't reinstall the stabilizers.
My understanding is that stabilizers cannot be used for jacking up the trailer, just for statically holding the back end up off the wheels. But your mod can do both, plus leveling, is that correct?-Brian in Chester, Virginia
@BrianZ
Correct. Plus the added benefit that you can unhook your trailer. Reposition your trailer on site to take better advantage of a view or site. Without having to roll up on leveling devices. No need to carry and store additional leveling materials or bulky devices.- Hash T@B Fun
2 -
Ah, hadn't realized the repositioning benefit, another bonus.
Here's a question about the mechanics of using your jacks fastened under the trailer for leveling:
If the ground is unlevel between the two jacks, wouldn't that put lateral stress on the jack & its mounting to the trailer (unless you could make a level spot on the ground area immediately under the foot of the jack)? I'm just trying to picture how the jack could remain vertical and not be leaning downhill with the slope. Or maybe the foot has enough flexibility to adjust to a slightly unlevel ground. Wondering what is the most out-of-level situation where you could still safely use the jacks.
RV: 2018 T@B 320S, >100 mods1 -
@BrianZ
In over 3 years we have never found a site that would not allow safe usage of the jacks.- Hash T@B Fun
@Dalehelman did mine also...LOVE 'em!2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf1 -
Dale, in for a penny, in for a pound. Sign me up to purchase these...Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI0 -
Done. I have 5 pair available.TerryV6 said:Dale, in for a penny, in for a pound. Sign me up to purchase these...- Hash T@B Fun
Dale, I'm ready to purchase these also. I will be at UCamp, so I can pay you then or send you a check. I also want to see if you will have time show me how to do the install. Do I just need to bring the scissor jacks?
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
BigGrover
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama0 -
Can do. The mounting plates on the jacks should look similar to the picture. You buy them in pairs for $60-$70. 24” jacks for 320 Max or 30” for boondocksdmerzbac said:Dale, I'm ready to purchase these also. I will be at UCamp, so I can pay you then or send you a check. I also want to see if you will have time show me how to do the install. Do I just need to bring the scissor jacks?
https://www.amazon.com/dp/B001FC74P6/ref=cm_sw_r_em_api_c_S3UkBbDZZXFRS
- Hash T@B Fun
I have not installed them on a 400 yet. I think the 400 uses the same stabilizer jacks as the 320 should work.BigGrover said:I would like to purchase a pair if they will work on the 400 but I won't be attending the Ucamp rally .- Hash T@B Fun
Thanks, how can I order the adapters from you?BigGrover
Central Alabama0 -
So Dale, if you need the money front, just give me a total..Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI0 -
No money needed up frontTerryV6 said:So Dale, if you need the money front, just give me a total..- Hash T@B Fun
Dale, how do you feel about shipping a pair? We are unable to attend Ucamp.2014 CS, tie-dyed exterior, "Tabula Rasa" and 2009 T@da also tie-dyed, “Grateful”0
Dale I would like to order a pair of adapters too.BigGrover
Central Alabama0 -
- Hash T@B Fun
Eric aka: Lone Wolf2 -
Delete
- Hash T@B Fun
Mine is 36092BigGrover
Central Alabama0 -
I currently have 5 sets at $25 per set. After these are gone it will be necessary for me to increase my price to $35. You can still make them yourself if you have an electric hand drill a hacksaw and file. Cost will depend on the price you have to pay for 2’ of 3/16x2” flat steel bar and 2 3/8” x1 1/4” carriage bolts.
Yellow circle dimension should be 5 1/4”
not 5 3/4”
- Hash T@B Fun
No problem, how much total for adapters and shipping?BigGrover
Central Alabama1 -
You should be getting a PMBigGrover said:No problem, how much total for adapters and shipping?- Hash T@B Fun
469962014 CS, tie-dyed exterior, "Tabula Rasa" and 2009 T@da also tie-dyed, “Grateful”0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
