UCamp 18 rally ( replace your rear stabilizers with true scissor levelers)
Dalehelman
If you are attending the rally and are interested in this modification contact me. I have a simple adapter that will allow simple bolt on installation. I can instruct you in making your own or you can purchase a pair for $35
  1. Hash  T@B Fun
«134
  • Homebodyatheart
    @Dalehelman did this mod for me and I love it! The Tab actually feels less bouncy with them, and three point leveling is a breeze! It’s also quick and easy to put them down and up with my cordless drill.
  • Dalehelman
    edited June 2018
    @Homebodyatheart
    Thanks for the review. I don’t do this for the profit just my time, wear and tear and materials.
    1. Hash  T@B Fun
  • jkjenn
    jkjenn Member Posts: 6,425
    Dale, I might take you up on this one. I will let you know.
  • BrianZ
    BrianZ Member Posts: 1,770
    I guess this would also provide built-in jacks for changing tires or wheel maintenance, plus avoid the guessing game of where to put a jack.
    Wish I was gonna be there.
  • Dalehelman
    edited June 2018
    @BrianZ
    The factory stabilizers can be used for tire and wheel servicing. It has been discussed at great length in many threads.  Basically chock wheels. Unhitch trailer. Lower tongue as low as possible with tongue jack. Extend rear stabilizers all the way to the ground. Then raise tongue till tires leave the ground. This provides a very stable three point platform to work from. Each stabilizer is rated at 1000lbs plus the tongue jack which is 2000 lbs.
    1. Hash  T@B Fun
  • BrianZ
    Yep, I think I've read them all.  But you wouldn't reinstall the stabilizers.
    My understanding is that stabilizers cannot be used for jacking up the trailer, just for statically holding the back end up off the wheels.  But your mod can do both, plus leveling, is that correct?
  • Dalehelman
    @BrianZ
    Correct. Plus the added benefit that you can unhook your trailer. Reposition your trailer on site to take better advantage of a view or site. Without having to roll up on leveling devices. No need to carry and store additional leveling materials or bulky devices.
    1. Hash  T@B Fun
  • BrianZ
    edited June 2018
    Ah, hadn't realized the repositioning benefit, another bonus.
    Here's a question about the mechanics of using your jacks fastened under the trailer for leveling:
    If the ground is unlevel between the two jacks, wouldn't that put lateral stress on the jack & its mounting to the trailer (unless you could make a level spot on the ground area immediately under the foot of the jack)?  I'm just trying to picture how the jack could remain vertical and not be leaning downhill with the slope.  Or maybe the foot has enough flexibility to adjust to a slightly unlevel ground.  Wondering what is the most out-of-level situation where you could still safely use the jacks.
  • Dalehelman
    @BrianZ
    In over 3 years we have never found a site that would not allow safe usage of the jacks.
    1. Hash  T@B Fun
  • ericnliz
    ericnliz Member Posts: 4,437
    @Dalehelman did mine also...LOVE 'em!
  • TerryV6
    TerryV6 Member Posts: 1,101
    Dale,  in for a penny, in for a pound.  Sign me up to purchase these...
    2016 NuCamp 320 T@B Max S
    T@bbey  Road
    Appleton,  WI
  • Dalehelman
    edited June 2018
    Done. I have 5 pair available.
    1. Hash  T@B Fun
  • dmerzbac
    dmerzbac Member Posts: 289
    Dale, I'm ready to purchase these also. I will be at UCamp, so I can pay you then or send you a check. I also want to see if you will have time show me how to do the install. Do I just need to bring the scissor jacks?
    2017 T@b 320 - 'Smokey'  2017 Toyota Tacoma TRD Sport - 'B@ndit'
    Dave - Tuscaloosa, Al
  • BigGrover
    BigGrover Member Posts: 450
    edited June 2018
    I would like to purchase a pair if they will work on the 400 but I won't be attending the Ucamp rally .
    BigGrover
    2019 T@b 400 Boondock Lite
    2018 Ram 1500 Quad Cab Hemi
    Central Alabama
  • Dalehelman
    edited June 2018
    Can do. The mounting plates on the jacks should look similar to the picture. You buy them in pairs for $60-$70. 24” jacks for 320 Max or 30” for boondocks
    https://www.amazon.com/dp/B001FC74P6/ref=cm_sw_r_em_api_c_S3UkBbDZZXFRS
    1. Hash  T@B Fun
  • Dalehelman
    I have not installed them on a 400 yet. I think the 400 uses the same stabilizer jacks as the 320 should work.
    1. Hash  T@B Fun
  • BigGrover
    Thanks, how can I order the adapters from you?
    BigGrover
    Central Alabama
  • TerryV6
    So Dale, if you need the money front, just give me a total..
    T@bbey  Road
    Appleton,  WI
  • Dalehelman
    No money needed up front
    1. Hash  T@B Fun
  • Carolyn
    Carolyn Member Posts: 129
    Dale, how do you feel about shipping a pair? We are unable to attend Ucamp.
    2014 CS, tie-dyed exterior, "Tabula Rasa" and 2009 T@da also tie-dyed, “Grateful”
  • BigGrover
    Dale I would like to order a pair of adapters too.
    BigGrover
    Central Alabama
  • Dalehelman
    edited June 2018
    @Carolyn
    @BigGrover
    I will check on shipping and get back to you. Please send me your Zip codes.
    1. Hash  T@B Fun
  • ericnliz
    :rofl:@Dalehelman, See what 'ya started! Grand opening: @Dalehelman's Mod Shop! =)
  • Dalehelman
    edited June 2018
    Delete
    1. Hash  T@B Fun
  • BigGrover
    Mine is 36092
    BigGrover
    Central Alabama
  • Dalehelman
    edited June 2018
    I currently have 5 sets at $25 per set. After these are gone it will be necessary for me to increase my price to $35. You can still make them yourself if you have an electric hand drill a hacksaw and file. Cost will depend on the price you have to pay for 2’ of 3/16x2” flat steel bar and 2 3/8” x1 1/4” carriage bolts.
    Yellow circle  dimension should be 5 1/4”
    not 5 3/4”
    1. Hash  T@B Fun
  • Dalehelman
    @Carolyn
    @BigGrover
    Shipping cost $7.50
    1. Hash  T@B Fun
  • BigGrover
    No problem, how much total for adapters and shipping?
    BigGrover
    Central Alabama
  • Dalehelman
    You should be getting a PM
    1. Hash  T@B Fun
  • Carolyn
    46996
