Shakedown cruise over, Gatsby and I have headed out. Either I’m confident all will be well and I’ll deal with experiences as they come, or I’m blind stupid headed into disaster. I prefer the former mindset.
Still haven’t mastered the refrigerator lighting on propane, despite doing EXACTLY what I’m told will work. In the interim, I have purchased a fairly decent cooler and merely transfer perishable food to it between plug in stops. Eventually I’ll get to the NuCamp factory and see what they can do or it will light reliably when I try. Grrr...
I feel like I’d be happier with an electric source other than expensive campgrounds. Solar or generator? If you have a generator, do you just run it for a little while? I don’t use the AC or TV and have no appliances other than an extra lamp or two. I think solar would be better but want it beefy enough to run the fridge (see propane problem above). I have no experience with electrical things so haven’t a clue about running wires, etc. 200W solar plus 2 6 volt golf batteries plus an inverter seems to be what I need. No longer having a home to which things can be shipped, I face the dilemma of how to get these things?
My fridge stressed me out the entire first year, so I get it!
Regarding the Norcold on propane. Here is some info from the forum that may help. The full discussion is at the bottom.
Let us know if you have success.
Sharon
Make sure your Tab is level front to back and side to side.
Close the valve on the propane tank. Then open it up slowly all the way. Make sure the stove stays lit before trying to start fridg. If propane valve is opened too fast, a safety valve inside the tank automatically shuts off the fuel flow. Leveling has no effect on lighting the fridge only when running it.
Someone had success by closing the Tab door. Breeze implicated in preventing lighting.
This sequence has allowed me to start the frig on propane on the very first try for over a year now. This is a 2016 Norcold with the "guts" on the left side:
Level the trailer.
Open valve on propane bottle very slowly.
Light one burner on the stove and leave it on for about 40 seconds. Turn off the stove.
Move the temperature knob on the Norcold to the 6 O'clock position.
Push the red ignition button in and hold until the green light comes on.
Wait no less than 60 seconds while holding the red button in with the green light on.
SLOWLY release the red button. The frig should now be lit and the green light on.
Hope this helps.
Am also a 2018 Model owner and had a bit of trouble getting the propane to operate the first time. While the above how-to-light instructions are helpful they all sound like pre-2018 Fridge model.
For the 2018 model:
- A - There is no green eye pilot light, there is an analog gauge, marked white, red line, green.
- B - The pilot spark button is just like a home grill one push equals one spark.
Each time the operator pushes the spark button the analog gauge jumps in the white area and returns to zero which is very,very confusing.
Fridge Owners Manual sequence has worked for me with minor forum additions . . .
- 1 - Trailer level.
- 2 - Propane on, and range burner test completed.
- 3 - Set Propane flame knob to high
- 4 - Set power source to Propane
- 5 - Press in and HOLD Propane flame knob
- 6 - Press spark button three times
- 7 - WAIT while HOLDING Propane flame knob in
- 8 - Watch analog gauge, normal start . . .
- 8.1 - needle will reach red line
- 8.2 - needle will enter Green area
- 8.3 - CONTINUE to HOLD Propane flame knob in
- 8.4 - needle will reach mid-point of Green area
- 9 - Release Propane flame knob.
Owners manual says press spark button up to five times seconds I've found with a new unit it lights in 2 - 3 sparks.
After the first training session I have started the Fridge on propane successfully three times** using the above 9 steps.
https://tab-rv.vanillacommunity.com/discussion/6733/2018-norcold-fridge-won-t-start-on-propane/p1
As for solar I just bought the ACOPower 120w portable solar setup on Amazon. It weighs just over 8#, a plus for me. I tried it last week while camping and could run my Fantastic Fan and charge my mobile hot spot at the same time, keeping 12.3-12.4 the whole time. I just picked up a 12v oscillating fan as I tend to wilt in the heat. Another Tabber and I bought them at the same time and she discovered that if you call the company and they can verify your order has been placed they will mail you a 15’ controller to solar outlet power cord, no charge if you offer a review. Add two padlocks and a cable strung between your trailer and the unit to lock it up and you’ve got a great setup! Good luck with it!
It stayed on for a few hours but went out before I got to my next stop a few hours later. I tried all the relighting steps to no avail.
I wrote in to nuCamp and they replied with these same steps, except to say the spark has to be clicked very fast, faster than you think. Nope. I have tried turning the tank off and slowly on, lighting the stove, setting the knobs just as directed, holding the valve knob in and clicking fast and slow and it has never never started. I admit to being grateful when I can plug in and not trying to light it except at moments when I I’m ready to move on. But I have to get it to work or I won’t feel happy dry camping.
2018 Nissan Frontier
Kennebunk, ME USA
British Columbia, Canada
The solar issue—I will continue to research the options. I’m actually in Sugarcreek now, planning to take advantage of a factory tour Monday morning. I’ll pay particular attention to where I can screw in things without encountering surprises behind walls.
I checked and they can install 100W solar in midSept for $1100, which is probably a fair price for that service but I’m sure I can do better myself with movable panels or ones I can attach myself. See how emboldened I’m getting to be? There’s hope for me yet! I still have a bit of work to do researching controllers and inverters.
Kennebunk, ME USA
https://www.acopower.com/product/solar-charger-pack/acopower-120w-12v-mono-foldable-charger
I’m just finishing up a stay in Door County , WI.
Have had electric plug in for the past week, but I have had success with the lighting the Norcold, so that’s something positive.
Kennebunk, ME USA
Congrats on getting the fridge going. That always feels like an accomplishment
