I have a 2017 T@B Q Max with the Alde heating system. It works on electric or gas, with electric being priority if you have both on at the same time. When I have electric off and the gas on in the Alde system It seems to heat inconsistently. For example we went camping for three days this past week and the first two days it heated fine but the third day/evening it tried to kick on then went off several times before showing “gas failure” message. By trial and error ultimately, I think, when we resort to tapping the “reset” button under the tools menu it seems to work again. Can anyone shed light on why this is happening?
0 ·
From the 3020 manual:
” Gas failure: Out of gas or gas is not igniting. Check that the gas cylinder is full. Try a different gas cylinder, ensuring it is propane gas. Check the gas regulator and that any isolation valves are open and not frozen. Ensure that gas is available.”
Another thing is check for the High Altitude Mode. Not saying this is the problem, just curious if that is a factor.
Sometimes if you open the propane tank valve quickly it will set off a safety shutoff feature on the propane tank. If your stove works this isn't the issue. If your stove does not work, try closing and opening the propane valve slowly and confirm propane flow at the stove. Then do a full 12V power down to reset the Alde and try again.
Remove the square, black cover on top of the Alde. You should see three wires connected to a terminal block. If I recall one is an ethernet lead. Unplug all three of these. Wait one minute, then plug them back in.
Had a similar problem last year and this "hard reset" did the trick. Dunno...but good luck!
San Diego, CA
www.airbossone.com
Good idea to do a hard reset in any case!
Photo too large and deleted. Please resize before posting. https://tab-rv.vanillacommunity.com/discussion/47/what-size-should-my-posted-forum-photos-be#latest
San Diego, CA
www.airbossone.com
