Verna
Member Posts: 6,876
Hmm.. As far is it not working on electricity - could you check to make sure you have had your Hot Water setting in the middle selection? If you have it on empty there will be no hot water or heat (not sure why its even an option), and when you have it on boost mode (full shower bar) it will only heat hot water and not heat the trailer cabin.
Another thing you can check is the Water and Glycol Boiler fluid temperature on the Alde Panel to make sure it is working - you will want to try it about 30min after turning electricity only on and allowing it to fully heat up. To get to this Temperature reading you will want to press the Key/Settings icon at the bottom right corner of the screen and then scroll 2-3 pages up and you will find a icon that says "Service" and then select that icon. When in the service menu you will want to scroll 1 page down and you should see "Glycol Temperature" and "Water Temperature”
A healthy Alde will have a Water temperature between 110-130 on regular Hot water mode, and between 140-160 degrees on BOOST mode.The glycol temperature should be around 165-175 degrees.”
So, I checked the screen for the hot water setting. That was easy! Move it to the middle setting, turn off the propane, and the Alde started giving me heat on electric! I’m a happy and warm camper!
And my water and glycol temps were within the acceptable ranges, so Creed agreed they were fine.
So looks like if the 3020 display for hot water is not shaded (empty), then the Alde is effectively off. Did you leave the propane off for testing purposes?
I looked at the Alde 3020 manual and I think I will offer myself up for interpretive services. There is some awkwardness with their explanations!
I tried the Alde on electric last week at the first campground I stayed at, and that’s when I found out it didn’t work on electric. I didn’t have time to diagnose it last week, but I did have time this week. At üCamp18, I used propane for the water heater part of the Alde to conserve electriity for others.
Yes, I left the propane off for testing before I sent Creed the email, and it is still turned off on the screen. Last night was the first night I slept with electric Alde heat. Now I’ll turn the Night Mode back on since I prefer to sleep a bit cooler than daytime temps.
I read the 3020 manual twice and I sure didn’t see an explanation for the hot water icon. I imagine when I set the options up, I mistakenly turned the hot water icon off, without realizing the ramifications of that action.
I also read through about 15 pages of the posts on the Heating, etc. Category without seeing anyone else who had the incorrect hot water setting. I stopped when I got to posts that were mostly for the manual controls for the Alde. So, this post will hopefully guide someone else who has the same problem.
It kept me warm in the other T@B and it’s keeping me warm in the 400. The only thing is when you overlook one little icon and each icon means so much.
While my favorite part is the heat and hot water, I absolutely love the Night Mode to set back the thermostat at night. It’s just like having the auto set back thermostat in a stick-built house.
After a while, you will get the hang of it and you’ll have it all figured out, and then it’s summer and you don’t need the heat. That’s what the forum is for—to be able to come back here next fall and double check your settings! Thank goodness for the forum, other owners and the factory...and if you’re in up to your shoulders, there is always Alde USA
Have seen Facebook Posts that claim Hot Water is hotter on Propane than 120VAC. I've not done controlled tests of that claim.
From experience do know the US Manual statement:
heating system are heated simultaneously, the hot water
can be very hot when a high level of heating is required.
Thanks
"Sparky" 2019 T@B 400
2017 Honda Ridgeline RTL-T
Flagstaff, AZ
That is, if the Alde is turned on (in this case electric or LPG) and if there is water in the tank, it is heated by default. We can't turn off that element in the 3010. Yet, we can still heat the cabin without any water in the Alde tank - no harm done. So, I figured, the 2 separate compartments in the Alde share their heat. The water chamber wraps around the glycol chamber and that's how the water heats up.
Here is a quote from online from Alde regarding the 3020:
"The heating fluid is propylene glycol antifreeze (ethylene glycol in Europe), and as it's heated, it exchanges heat through a stainless steel jacket with the domestic hot water (DHW) cylinder. If the DHW cylinder is full, the water is heated and also acts as an insulator, if it's empty, air is heated but no damage can result."
So enjoy your cabin heat!
Thanks tons!
Peter
Flagstaff, AZ
@Verna, @Petroffski
I contacted ALDE-USA about this and got mixed responses. Initially, Spencer quoted the user manual and stated the Cabin Heat should be on when the Hot Water control is set to Off (wedge empty). So I asked the question again since folks are reporting different results.
Spencer then tested his system with Only Electric Heat Source (full 2kW) and Hot Water wedge empty and his system heated the glycol as it should . . . heat elements did not turn off . . .
However, do not know which Alde Model 3010/3020 Spencer has or what Control Printed Circuit Board revision his system uses. Which could be why Spencer also stated this could be a software bug and we should provide documentation for him to forward to the factory.
Would some one with the issue and not winterized care to document?
Maybe control panel pictures;
(1) showing 2kW and/or 1kW 'On', propane 'Off', Hot Water wedge empty.
(2) Main panel showing a high cabin set temperature and status of glycol pump.
(3) Service Panel showing system temperatures.
Spencer's Email:
Other (MuttonChops thoughts, not Spencer)
NuCamp's comment that the Hot water empty wedge, hot water off, is meaningless does make sense. As long as the Adle has water in the boiler there will be hot water, you cannot turn it off as the water is heated by the glycol. If an empty wedge does turn-off the electric heating elements than that would be a software bug according to Spencer.
Perhaps setting Hot Water wedge empty when only on electric power causes the Alde to demand/set a lower glycol temperature (no need to heat water) which causes the cabin air to warm more slowly and we users 'feel' that means the cabin heat is not working ? ? ?
Sold 2023 Tab 400
Sold 2018 T@B 320S
When I tried the 1K setting, I checked it in the morning and the glycol temperature was a blistering 31°. That is 5° colder than when I set the heater the night before. So no... while a good thought, it certainly isn't true in my case. 3020 definitely NOT working.
You mentioned in your most recent post about testing and taking pics while not winterized. Would winterizing be a problem for the heater? I can't imagine why except to possibly add unknown variables.
Flagstaff, AZ
Flagstaff, AZ
Flagstaff, AZ
