Does someone know of a way to install a sturdy grab handle on the inside of the camper as you exit? I'm always grabbing the frame of the door and will eventually pull it off as it's only plastic. I've had to tighten the frame. I don't thing there is anything solid that I could screw into next to the doorframe. I know there's a good handle outside the door, but it's intuitive to try to grab something inside before stepping outside. I usually have to exit backwards so I have a handle to grab, or try to remember to grab the wooden frame up higher where the light switches are. It would be great if there were a wooden stud next to the door frame for this purpose. Thanks for any comments and help.
0 ·
https://www.campingworld.com/lend-a-hand-rv-hand-rail-sparkling-silver
This one folds away from the door which might be better. You'd have to find one small enough to not get in the way of the side window.
https://www.campingworld.com/lend-a-hand-rv-hand-rail-black
I think this one has been set up to close over the door.
https://www.campingworld.com/soft-touch-rv-assist-handle?rrec=true
This one doesn't fold, but may be small enough.
I think you need to call Elise/NuCamp and ask if the side can handle a grab bar. Would you have to put supports on the opposite side of the composite/aluminum skinned wall? Would there be something there already?
Like this..
Safari Straps EZ100-BLK EZ Grab Handle Black w/Footman Loop https://www.amazon.com/dp/B00HRIHQNC
Or..
Smittybilt 769402 Black Winch Hook Grab Handle with Premium Pull Strap https://www.amazon.com/dp/B004K23K60
Or..
3 in 1 Automotive Assistant Kits Car Handle, Standing Support Car Cane, Headrest Grip,Adjustable Mobility Aid for Grandparents Patient Elderly Lower Strength by OasisSpace https://www.amazon.com/dp/B07CG5HFRX
Or there may be a similar, but DIY solution, like a piece of nylon rope looped through a 6" piece of water hose plus a fastener, or just feed through a hole & knot the end.
Not sure about strength of the shelf bracket, but it's quite strong & probably wouldn't routinely be subject to that much stress, since it's usually more a matter of balance than putting all of one's weight on it.
Am also very interested in placing an inside grab handle (teak) by the door right side.
Same as @jgram2 I've searched the “factory tour” videos and pictures with no luck. Which is no surprise as NuCamp has the sidewall panels fabricated by a subcontractor. Sidewalls arrive complete with nothing useful to see, inside structure wise.
We need NuCamp to provide the sidewall construction drawing for that area of the 320 passenger sidewall. Something like:
{ 11/27 edit figure removed }TV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Have wondered the same but not gotten around to removing the outside handle for fears of:
(1) still won't be able to tell and
(2) might not go back together as firmly {not knowing what it mounts to}
So will you be our lead to contact NuCamp ?
Judi
what does your teak handle look like and where do you get them? Bill
Sorry I can’t provide a photo.
https://tab-rv.vanillacommunity.com/discussion/7828/bathroom-marine-grab-handle
If this information is insufficient, I recommend one of you calling nüCamp as my descriptive powers have maxed out. I’ve been exchanging emails with Creed, nüCamp’s number: 844.823.9112
I took them off and bought an adjustable folding step instead. It's much more secure and I really don't have to grab onto anything on my way in or out.
More Wondering - - -
By looking into the door latch plate the Wall Metal Frame and outer panel can be seen. So in an attempt to better understand NüCamp's statement on the placement of sidewall metal frames I've created a model of the Door Wall Outline by taking measurements with a Contour Gauge and starting the wall based on what can be seen/measured at the latch plate.
The Metal Frame starts about 0.5 inch from latch plate surface and would need to be 2x1 for the outside handle to screw into metal as NüCamp stated.
Current Thoughts:
Am considering forwarding this to NüCamp to request additional clarification - - - once I can clearly show and ask (write) what I need from them.
My only concern might be that, because the handle appears to be shallower than the inside door jamb, there would only be about a half inch of space for one's fingertips to wrap around the handle, and that might cause them to get stuck in that tight space when trying to let go of the handle & cause injury. Alternatively, grabbing just the inside (3/4 of the handle) might be sufficient.
A deeper handle with the same screw spacing might be ideal.
