The users manual which came with my new 400 is dated 2017 and doesn't cover many of the new features including something as simple as how to change a flat tire. Seeing how the unit doesn't come with a jack nor any stickers saying "PLACE HERE" and the factory video for the 320 jacking procedure conflicts directly with the owners manual on the use of the stabilizers, I'm looking to put together an update to the manual both for my family and the NuCamp community at large. My rationale here is that the manual should be a "go-to" tool for when you are stressed and everything has gone sour and you just need a simple direct answer to what seems at the time to be a monumental issue. So, while things are calm between now and the next outing, I've started that process.
That said, I can really use some help as we've only owned our trailer for a few weeks although we've traveled in a 2017 for a month. Please use this discussion to post suggestions for what to add so this Users Manual can become a reliable tool. As a personal appeal, could someone please post an accurate procedure for changing a tire that applies to the 400 and not the factory video for the 320. Any postings by NuCamp would be greatly appreciated.
I'd also like to point out that the manual, with all its limitations, is far ahead of what NuCamp's competitors put out. Its just that it can be better and there has been so much change. Something as simple as the recommendation for cleaning the filter on the Cool Cat says to slide it out of the unit but there isn't anything explaining where it is and how to slide it out. What may seem obvious to one person is not to another making this forum both valuable and a tool to maintain a continually updated users manual.
If others think this is helpful then great. If not, I'll just update for my family and move on. Curious to see what the feedback is and hoping someone knows how to change a tire on this thing.
F150 Pulling 2019 T@B400 BDL
7 ·
If you find an approved solution for changing a tire on the TAB 400 I would sure like to hear about it.
Or, if someone has figured out a good way to jack without hauling around the floor jack that is the recommended method, please chime in.
The verbatim confirmation of the location is here and my photo is my interpretation of these words. A photo was provided of a 320 that is also on this forum but not of the 400 although was told both will look the same.
"There should be a rectangular platform right behind the wheel where the Axle is attached to the Frame, It is the strongest point of the trailer. I would recommend placing the bottleneck/scissor jack there"
I agree with your analysis of the 400 jacking point and the danger of a bottle jack. I've been looking for a small, light scissor jack. I had a 2000# capacity in mind since one would not be lifting the entire trailer at once. Unfortunately I have not found any scissor jack--at any rating-- that has a large footprint, a large saddle and a hex nut for turning the jack screw. Most of the jacks I have found don't seem stable enough to support themselves even without a load. And the saddles are hardly larger than a bottle jack. What to do, what to do?
https://www.amazon.com/dp/B01N7Y678W/
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
Note - additional fuses were found while diagramming the electrical system so this section has been reposed below.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Central Alabama
Based on the completed topic index and general outline sketch, the first working daft will be around 45 pages and should be done in the next couple of weeks. Most difficult part is figuring out what is installed on the TAB so it can be described, documented and a troubleshooting series created. For example, I’ll be dropping the belly pan this weekend to figure out what axle is actually installed so a spare parts list can be made for the bearings. While I’m there, I’ll be measuring to figure out how to install the black and grey tank heaters. I really only have the weekends to work on this hence the intermittent responses.
Central Alabama
Central Alabama
Huntington LI
4.8 amps DC each
https://www.etrailer.com/RV-Fresh-Water/LaSalle-Bristol/277-000164.html
Yes, we do in fact have some stick on heating pads from etrailer on our fresh and gray water tanks and valves in our T@B 400. We wanted to avoid the need to winterize just for a night or two of subfreezing weather in places like Crater Lake in September or the mountains of New Hampshire during Fall Foliage but wanted to be sure the amp draw would allow us to continue to camp off grid. We purchased some ThermaHeat RV Dump Valve Pipe and Elbow Pads and a switch from etrailer.com. NüCamp R&D is aware of our design and we had it and piping insulation installed by Austin at the nüCamp Service Center.
The four 13"x3" (two per tank) and two 8"x3" pads (on the piping next to the gray and black valves) have a collective amp draw of just over 3 amps and are wired to a single rocker switch (located just above the monitor panel near the entry). We successfully used it a couple of times this fall both off grid and on shore power.
4 - Item # 277-000161 ThermaHeat RV Valve Pipe and Elbow Pad 13"x3"
2 - Item # 277-000162 ThermaHeat RV Valve Pipe and Elbow Pad 8"x3"
1 - Item # PK34310 Universal Design Rocker Switch
Our plan was to extend our camping to 3+ seasons, giving us the chance to stay out when overnight temperatures drop enough below freezing to be a concern but we don't personally plan to be out in really cold situations when the temp is below freezing all day. The Black tank is in the interior of the trailer (under the toilet, on top of the floor) and since we plan to use the tank heaters only when we are using and thus heating the trailer, we didn't add any heat to the black tank therefore keeping the amp draw down.
This has been revised 1-17-19 below
SF Bay Area
