I am a bit OCD about my battery dying as I rarely camp where there are hookups. I have an early model T@B 400 (2018) with the AGM battery and factory installed solar panels which lasts ~3 days in cloudy weather. I also recently moved my trailer to a storage facility instead of parking at my house which means I no longer have a power source to charge the battery before or after a trip (besides a noisy/smelly generator). Has anyone installed a Redarc battery charger? Wondering if this will prolong my battery usage. Thanks!
p.s. I am a software engineer, not an electrical engineer... I am pretty klueless on anything electrical!
https://www.etrailer.com/dept-pg-Battery_Chargers-sf-Battery_Charger-sz-Vehicle_Battery_to_Auxiliary_Battery-pm-Redarc.aspx?utm_source=iContact&utm_medium=email&utm_campaign=etrailer&utm_content=190408-T-RV-SR-V-BCDC-ManufSP-B                | Girl Glamper | Austin, TX | 2018 Land Rover Discovery | 2018 T@B 400 |
Partner in Crime: Black pug (Lulu)
0 ·
I thought this looked like a very interesting solution.
The benefits, as I read them were:
Faster charging
Outsmart alternators
Charge from solar and the alternator, with the built in MPPT charger
Can charge luthium.
Ha!!! Yes!!! I was hoping someone in this forum was smarter than me and could explain what it 'really' does!
It will depend on your TV. The gauge of wire won't make a difference of you have a smart alternator, which is becoming more common to reduce emissions.
The Alde hardly uses any power on propane. Also, "pretty low for most of the trip" is sort of vague. How are you monitoring your battery? Can you give us specific numbers on "pretty low?" If you were trying to get a reading on your battery and the battery wasn't "at rest", then it will always read "low".
Is this the answer to folks running their 3 way frig on battery while towing?
Your solar charge controller should be able to manage your trailer batterys.
How does the Victron MPPT controller behave when there's a second source of charge being applied to the battery? For example, if connected to the seven pin of the TV while simultaneously connected to your solar system?
Isn't the TV alternator's charge rate going to confuse the controller as to what stage it's in?
I imagine the new box would be the same way. As long as the source battery alternator combo has a higher voltage than the second battery or the voltage set point it will charge it.
With out testing I imagine both boxes will charge the battery till it hits their various charge points bulk float and absorption
The biggest job of this box is isolating the tow vehicle battery from the trailer battery.
As far as emergency vehicles, I have never seen anyone shut vehicle off while on a call, but I get the importance of an isolation device. I have LED strobes on my work truck and can leave those on for hours with no issue, I think today with almost all emergency response vehicles using LED it is less of an issue.
I would like an isolator, the renogy is close enough to that price I am sure it is possible. The other thing to keep in mind is renogy is just a remarketer. I am hoping the same thing happens that has happened with the solar controllers. Rich solar introduced a solar controller identical to the renogy for 40 percent less. We will see
https://roadslesstraveled.us/charging-rv-marine-batteries-solar-power-shore-power/
