rfuss928 said:FWIW - It is easy to twist a pair of long wires together using a power drill. No loom or tape required.With a quick search I found this youtube with a fair description. There are probably more detailed versions.For a long pair it is helpful to have a second person holding the loose ends keeping them taught and a bit separated until the twist reaches their end and tightens up. Pull as it twists and over-twist initially because the pair unwinds a bit when the ends are released.The large gauge wires will be a bit challenging but the method will work and last. Hold tight and pull hard.(snipped video)Have fun................
ChanW said:Huh! Good idea. I wonder how easy it ends up being to coil it up, or get it to lie flat, after it's a 'twisted pair'. Someone should try this with their 10ga solar cable (and let me know!)
rfuss928 said:ChanW said:Huh! Good idea. I wonder how easy it ends up being to coil it up, or get it to lie flat, after it's a 'twisted pair'. Someone should try this with their 10ga solar cable (and let me know!)Generally it removes the curl from being spooled completely and lays straight when done. Then it coils up like any other cable similar in size. I've often done #12 pairs with no problem but don't recall trying #10 or #8....Much easier to handle than this>>>
