We can't seem to get anything working in either of the two USB ports in rear driver side corner that we were using yesterday. Tried cell phones & a USB light, but the lamp in that corner works. Haven't checked fuses yet, as I think other stuff on the same fused circuit works. Front USB ports above sink work. No recent rain.
We have solar & ARB frig connected to battery. T@B frig is on propane & other background devices are working. Solar is mostly shade, fluctuating between 5-10W.
Any ideas?
2 ·
Nucamp sent me one for free even though it was more than a year old
would be interesting to know what was charging the last time they were working. Charging one item might be right, charging 2 might be to much and they burn for overworking.
also, some phone or tablets need more amps for same voltage to charge efficiently. I know that my small samsung galaxie T@B 8 need way more amps to charge than my I pad mini or my I phone, and that my Tablet oem charger will do better than the large block from my I pad to charge the same galaxie T@B.
i am not saying that this is rght and how they should be used, but only trying to exposed what kind of weakness they would have. Those chargers are transformer and being such, they are also generator of phantom power drain.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
I replace all of them with standard 12V connections and use plug in 12V to USB adapters which are cheap and easy to throw away and replace.
Definitely not a Ucamp thing.
Just one persons’s experience.
Do not plug your new ARB into the “Y”—the wire gauge is too small for the ARB’s compressor to work properly.
Carviya Motorcycle Dual Car Cigarette Lighter Splitter 12V 24V Charger Power Socket Adapter Plate Panel Mount + 4 Screws 4 Screw Caps https://www.amazon.com/dp/B0179WI9XG
12V Cigarette Lighter Socket Car Marine Motorcycle ATV RV Lighter Socket Power Outlet Socket Receptacle Waterproof Plug 2Pack By MXRS https://www.amazon.com/dp/B07QN2ML4X
Update: This is what I ended up using to replace our dead USB ports (along with a separately purchased Anker 30W USB plugin charger linked below). I installed one & saved the other for whenever the other USB sockets in kitchen area die.
perso, I stay away from 12 volts cig usb adapter as much as possible. Only have them for what was already 12 cig lighter plugs like the ARB fridge.
beside the comment I made up here, the two port usb connector in the foot wall of our T@G is still working after 2 years, but we do not use it much. I have install an 2 port usb charger in the head board cabinet (our 2017 did not came standard with one) and also install an on-off switch for it. Still working after 2 years. Like most of them, the lower port is higher amps than the higher one.
i did install a similar plug in both my TV also with and on off switch, and the oldest one is still workin fine after 4 years. Charging a samsung tablet (gps maps application) and my I-Phone. That will be connected for hours at a time, and no hick ups. The cig lighter adapter did not have the same amps cap at the time I started this set-up. And that also leave my plugs available for other chargers and gizmo, like charging my dji drone batteries while on the go.
but this is my experience and I know that others had issues.
AUKEY Car Charger, Flush Fit Dual Port 24W/4.8A Output for iPhone Xs/Max/XR/X/8, iPad Pro/Air 2/Mini, Samsung Galaxy Note9/Note8/S9/S9+ and More https://www.amazon.com/dp/B00M6QODH2
Update: Sorry, but I cannot recommend this. See my 5-19-19 comments below.
I found a review on the above posted Aukey ports which said it only worked in a car, but not in a travel trailer. Then I also found this other one claiming to support our particular phones with the variable charging voltages..
Car Charger (Compatible with Quick Charge Devices), Anker 30W Dual USB Fast Charger, PowerDrive Speed 2 with PowerIQ 2.0 for Galaxy S9/S8/Edge/Note, iPhone XS/Max/XR/X/8, iPad Pro/Air 2/Mini, and More https://www.amazon.com/dp/B07H4LH6P7
So, I'm hopeful that one of these chargers with higher amp ratings & the variable voltages to support our phones will provide what we need to avoid burning up USB ports, especially when charging two phones simultaneously, which can be close to 5 amps. An older standard USB port just isn't designed for that much power. It is interesting to see the wires coming out of the back of our T@B's dead USB ports - extremely thin gauge, especially compared to those going into the cig lighter port next to it.
Not crazy about the LED lighted sockets, but it's not too bright & can always be unplugged. Otherwise it's a good solid fit, unlike the Awful Aukey which was too stubby to stay in either socket to make contact without holding it in place. It also lacked the 3-voltage capability that Samsung's Qualcomm processor uses for fast charging.
I used tap splice connectors (the blue plastic things; 16-18G size) to tap into the main wires using part of the cable that came with the socket & already had push-on blade connectors. The splice gadget just slips over the source wire & has a hole to insert the connecting wire, then you squeeze the metal blade down with plyers & snap the plastic cover closed - takes about 5 seconds, and no stripping or soldering wires. I cut and capped off the old skinny USB wires tied around the others. It is similar to, if not the exact same as this..
3M(TM) Scotchlok(TM) Electrical IDC Connector 560B, Blue, 18–16AWG solid/stranded, 14AWG stranded, 100ct https://www.amazon.com/dp/B0002BFZ8E
The Anker USB charger ports work well in the new socket & successfully fast charged my phone as indicated in the display with an estimate of 30 mins until fully charged.
I plan to return the Aukey & do NOT recommend it due to its stubby design.
When I started this search I really did not fully appreciate how different USB ports can be, and how some of them are bare bones specs while others are designed with electronics that can substitute for one or more manufacturer's AC adapter charger in terms of the kind of USB power those provide, like little multistage charge controllers, except that these are made for plugin to car 12V cig lighter sockets. In this regard, it seems logical to avoid hard-wired USB ports & use a cig adapter instead, so that they can be easily updated or even instantly switched for newer or different models of phones/devices. They are also portable for moving from rear to front or in the car.
PS:
The trim plate pops right off if you pry the edges up with something thin & flat. Then there are 4 small wood screws to remove the mounting plate with the sockets held in place by rings that screw on from the back. Very easy, but you may want to pull the fuse on the circuit you're working on just to be safe, even if I didn't.
I know that Nucamp use them all over, but they are not good. Only quality, is fast in production line.
Used to work for a company that was in comunication equipment for city buses, subway train like New-york city, and trains for public transit, and we were forbiden to use those.
It is like you would use house slice conector, but in a way, they can be worst.
soldering is the way to go for that type of jonction.
hope this works for you.
2014 Mazda CX 5
Traveling very light to be kind to my transmission.
2014 Mazda CX 5
