So, while I was poking around Amazon, I did a search for "Keder rail awning"
I found several offerings of the keder rail strips that appear to be meant for "sew your own" projects.. It's like $16 for a 16 foot strip.. I'm ... inspired...
https://www.amazon.com/Keder-8-5mm-Welded-Standard-Black/dp/B010G1AXZO/ref=sr_1_2?keywords=keder+rail+awning&qid=1560540184&s=gateway&sr=8-2I have been wanting to maybe do an awning or a side tent.. but they're so darn costly.. and I had been thinking that maybe I could fab up something usable...
~Tananda
2019 T@B 320 S Boondock Edge named "Binky" | TV: 2016 Chevy Colorado Z71 with full tow package and a Leer Cap for lots of storage
0 ·
https://tab-rv.vanillacommunity.com/discussion/comment/100907#Comment_100907
2018 Tab 400
2019 Tundra CM
Wisconsin
2017 T@G XL
https://tab-rv.vanillacommunity.com/discussion/comment/113738#Comment_113738
There’s an easy pattern on one of the T@B Facebook groups for a visor-like awning.
EDITED FOR PHOTO SIZE - Sharon
I am doing something ish between that and what @Photomom suggested at the moment.. I have this 3 sided canvas "cook shack" which is an extension of a canvas tent I used previously for my medieval reenactment stuff (it's 12'x10' or so and has 2 walls, a door wall and an open back which nicely sits over the side of the T@B
With the awning ideas, I'm looking to diy something that is a bit smaller/more portable.. similar to the thing that @DeltaPop and @elbereth linked
Though these are great ideas .. Homebody - i really like how well yours fits
Go Hawks!
2016 Max S, 2011 Volvo XC60
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
@rkj__ Yeah I hear you about fast setup/breakdown.. this is why I will likely keep my "cook shack" for bigger things I will be there a while .. (it has 6' poles so it's kinda big and the canvas weighs #40 or so.) but will try some DIY awning I can use for just popping about.. I don't think an awning would be a huge time setup. and I just like the idea of having even a bit of shelter over the door so I an avoid rain getting in...
Homemade. Bought the Keder rail strip and lightweight silicon coated tent material. Rolls up to about 30" long and 5" diameter including the poles.
Yes, on the sports team reference, Go Hawks is for the Seattle Seahawks :-)
Awning works great unless it is really hot out, then it tends to trap the heat. We use a standard 10x10 white canopy with no sides when it is really hot out.
8.5mm (5/16") is what I ordered
https://www.amazon.com/gp/product/B00P6O8LRE/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
2022 Ford F350 Tremor | 2022 Cirrus 620
Amazon King Camp auto side canopy for minivan, MPV, SUV. It is 10’8” x 8’2”. The directions are not very good so it took some time to figure out how to set it up. Put the two long, bungeed cross poles through the sleeves and into the top corners and then place the cross-pole side to side across the top. Next, attach the front poles. Then lean the edge with the large bungees cords up against the TaB and run the bungee cords with some extensions over the top of the TAB and hook them to the driver-side fender well. You can leave the sides down or roll them up which is how they are in the photo. There are poles for the corners that hold it up on the side away from the trailer. There is a good video on the King Camp site. It comes in a small bag which is only a little less than 2 ft. long and fits nicely in the TaB under bench storage.
https://www.amazon.com/gp/product/B07B635CM6/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
I sewed keder roping along the blue fabric on the wider end so we could tie down the "wings" if necessary. In the photo, the white "wings" are rolled up so a breeze can pass thru. We put it to use while camping in the Adirondacks and it worked like a charm. There are grommets about 2/3's the way towards the poles that we tied down to create a valley for rain water to run off and lowered the two outside poles. When this one finally wears out, I'll probably do it all over again. Just use a sewing needle in your machine for denim and it sews beautifully.
Harpers Ferry, WV
