All users please be aware that the forum will switch to the new format this weekend (May 2-3 2026). You will see some changes in font and color and location of posts but basic functions should remain the same. Please post to the Help category if you experience issues.
Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
Best Levelers?
wooper
Member Posts: 75
Just purchased a T@B 320. Researching levelers and looking at the Andersons, the BALs, and the Lego type (Camco and Tri-Lynx. Leaning towards the Anderson but would like some input from users. Thanks
2017 T@B 320S, 2011 2WD Honda Pilot, Coming out of The Woodlands, TX....Mark & Carolyn
We like the Anderson levelers. We had used the Legos but now they stay in the bag as the Andersons are much simpler and thus quicker. I have a pair which I use for the winter storage as an attempt at minimizing flat spots with the larger tire support.2018 T@b 400, 200ah Lithium with Solar
2013 Tundra TRD 5.7L
Massachusetts -
I've used the blocks, Anderson and BAL. I prefer the BAL because it provides 10" of height and can be used with a 3/4" cordless drill. However, it is heavy and somewhat cumbersome.2016 Outback 320
We use the Anderson routinely and we have a set of blocks that we have used once. Anderson stores easily, relatively light weight. We learned that you may not be able to open or close the coupler latch unless fully off the Anderson!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
@tabaz read the reviews on amazon regarding using a cordless drill on that leveler. it isn't recommended and they will not warranty it if damaged.
2009 GMC Canyon, 3.7 liter
2020 320s Boondock lite, With Lots of mods -
Love my BAL. I can position the trailer any direction on the campsite and then level it. With the legos and the Anderson, you have to use your tow vehicle to move the trailer onto the leveler.
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL -
Note the use of "we" and "I". Anderson is great if you have a spotter. BAL works better for one person.
Towed by 2014 Touareg TDi -
I love my Legos....there, I said it 😂Verna, Columbus, IN
@Verna, X 2!2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus. -
So far, I’ve used lego blocks and the BAL. I prefer the BAL, but it’s definitely got its drawbacks...heavy, big, needs to be lubricated periodically, and as Cbusguy points out, using a drill may increase the odds of stripping the screw. I use a socket on an extendible ratchet with mine.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW -
@Verna, X 3! (You are so brave, but somebody needs to get the ball rolling.
) 2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ) -
We are Anderson users. In going on 7 years it has been insufficient in height only a couple of times. We also carry a couple of 2x6s that can be used to supplement the Anderson. Easy to store, no moving parts.Jupiter, Florida~T@B 400, with 2018 Toyota 4Runner
The legos are simple and effective, and they are not a single use item. Being a backcountry backpacker & technical climber multipurpose is key in gear selection.
2018 320S Outback -
We just used our Bal on concrete for the first time, the only time we needed to level on our 3 week + road trip. We’ve only ever used the ratchet wrench it came with I think. Old back old knees and arms, no problem. The gentleman next to us, using legos, was thrilled at the Bal option. As we all know, whatever works best for you.John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
Cbusguy - no need to review Amazon reviews and don't care about a warranty on a low dollar item. With judicious application of the drill (slow, slow, slow), I’ve found the BAL to be the best option for my mission. However, your comments are important for those considering various options. The torque generated by the drill leveling the T@B is significant and may be too much for some people. Anyone considering using a drill with the BAL should read the reviews as you specified.2016 Outback 320
You might as well ask what’s better, MAC or PC, Apple or Android, Canon or Nikon.
Because I use them, I will assert that plastic blocks, the kind that lock together like Legos, are the best. Cheap, can’t break, brightly colored so you don’t accidentally leave them at the campsite.John and Henrietta, Late 2016 T@B S Max in Western New York -
I often reposition the T@B at least a little after disconnecting from the TV - sort of makes the BAL our only choice.Plus, Only a BAL can do this:
@4ncar, I agree. Your comment reminded me how many times I have used the Lego type levelers to level camping equipment, such as a stove. Also, if I stop in a campground just for an overnight stay and I don't want to unhitch, I use some levelers to raise (or lower) the angle of the rear of my truck so as to level my T@B front to rear. I did, however, recently make the bonehead mistake of trying to back my truck onto a couple levelers for that purpose. The torque from the rear tire of my truck grabbed the Lego block and cracked the outer edge. Always best to pull forward onto a Lego or similar type leveler.4ncar said:The legos are simple and effective, and they are not a single use item.2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
When I cleaned out my Tacoma to trade it in, I kept about 6 Legos just in case the pop-up thunderstorms dumped so much rain that I needed stepping stones (Legos) to get to my camper. Luckily, my campsite didn’t get any water, although there were a few that would have needed more than Legos! Multi-function—yes!Verna, Columbus, IN
BAL leveler
update 19 Sept: I’m sitting here at a the campground at a teardrop trailer meet. Watching people set up. The ones which “LEGO blocks” pulling back and forth leveling. Folks like us with the Bals, pull in, slide the Bal under, level and done in about three minutes.2022 TAB 400 Boondock, 2019 Toyota Tacoma Sport 4x4
Odessa, Fl.
Tossed a coin...got the legos. Thanks for the suggestions!!!2017 T@B 320S, 2011 2WD Honda Pilot, Coming out of The Woodlands, TX....Mark & Carolyn
@wooper- which brand of lego did you go with?Aggie/ 2021T@B320S; Alde Compact 3020 HE/ 2021 Subaru Ascent
Rockville, MD (a D.C. suburb) -
@ZippyA Camco...used it a couple of times and they worked well. Light weight and easy to store. Long term life...I'll have to wait and see.2017 T@B 320S, 2011 2WD Honda Pilot, Coming out of The Woodlands, TX....Mark & Carolyn
BAL- no need to guess how many, no need to re position- just insert and raise it up
2x8x24" wood blocks like @ScottG showed, plus Anderson leveler. We use the Anderson in most cases for fine tuning, but may be used on top of wood for steeper grades.-Brian in Chester, Virginia
- 15 "FOR SALE" - New/Used Trailers
- 135 Help - Computer & System
- 915 Introductions
- 72 Teardrop Groups & Links
- 913 Tips & Tricks
