I'd like to do a thorough check of everywhere on my T@B that may require fresh caulk. Has anybody put together a guide of where to check and what to not refresh? I know I can do a walk-around and use my own eyes to figure out where caulk should go, but I might miss a spot or put caulk somewhere it's not needed. E.g., I understand that caulk is not needed around the colored trim pieces.
Thanks in advance,
Matt
Matt
Appleton, Wisconsin
2006 Dutchmen T@B ("Fuego")
TV: 2007 Nissan Pathfinder
1 ·
Appleton, Wisconsin
I found this link, which may help, but in addition to that, read on:
https://tab-rv.vanillacommunity.com/discussion/6471/important-maintenance-reminders
As I believe you have already alluded to, the only obvious location in the first photo is the horizontal bar indicated with a yellow arrow in the photo below. You can see the caulk/sealant along that section of metal. I have not looked closely at the frame around the wheel well, but I presume it looks the same on the frame both forward and to the rear of each wheel.
Although I could not quickly locate it on this forum, I searched through my files and found the following info that was posted by @Michigan_Mike in May 2016. It has a slightly better explanation of why the factory sent out the maintenance notice. I have also included some additional (itemized) info regarding the specific areas involved, which I assume are responses to questions posed by @Michigan_Mike (or someone else?) I highlighted the most important information:
ATTENTION! - Special Factory Maintenance Notice
Michigan_Mike (May 2016):
This information was passed along to me by the factory and they asked that we share this with forum members, so please take a few moments to read it:
If your trailer is 1 year or older, we want to encourage you to properly maintain it. As you prepare for the camping season, it is vital that you do this – and it’s the perfect time before you start travelling/camping.
Perhaps the most important thing you can do is to check the seals. If any of the seals are cracked, you must re-caulk them. From time to time we have clients contact us with 2 and 3 year old trailers that have experienced some level of water damage. Upon investigation, the reason, more often than not, is that they did not stay on top of the seals. We don’t want anyone to experience water damage – it can lead to something ugly, like stained or swollen wood or something horrendous like an entire floor or sidewall replacement, depending on the trailer.1. Door. Yes, under the silver door frame, not under the (red) trim.
2. Fender. There was no picture of that. If you look at your trailer from the side, you will need to remove the actual fender – 7 total screws. 5 on the fender itself…Be careful not to miss the 2 on the bottom that screw into the adjacent trim pieces.
3. Wheel Well. The picture of the black material with black caulk is for the wheel well. Caulk both sides.
4. Kind of caulk to use: Any caulk that is exterior protected.
And, @lkc001, as far as the wheel wells, based on what I read, it appears that you will want to check the areas around the wheel well indicated by the yellow arrows in the photo below. AND, after removing the wheel fender, the area around where the fender attaches to the sidewall of the trailer (red arrow.) I am guessing that once you remove the fender, you will see the sealant used at the factory and will also see any potential cracks/gaps that have formed over time. It would probably be a good idea to put some caulk/sealant in the screw holes as well before reattaching the fenders. (NOTE: back in June 2016, @SweetlyHome posted some photos and info on what they found when they removed their fenders. I could not find the original post, but they did find cracks in the sealant.)
As far as the door, this is a photo that @Michigan_Mike included in his post:
I am assuming that you need to seal the area under the metal where the arrow is pointing.
Bottom line of all this is that you should, at least annually, check ALL areas where there is caulking/sealant, both inside and out of the trailer, and re-seal as needed.
Sorry for the long post, but I hope it helps. (Greg)
When I look at my Tab, I see NO evidence of caulking between the plastic wheel well trim and the outside wall. The plastic trim is just screwed into the Tab sidewall. I can see daylight in the spaces between the screws. I also would think it would be a concern to take the trim off every year? Won't that weaken the screw holes over time? The side walls are not solid metal or wood with permanent threaded attachments. Then what if the screw holes won't even hold the trim in place?
I can clearIy see from the INSIDE passenger bench seat the caulking painted around the wheel well, which makes sense to check this and reapply as needed, but again, WHERE on the outside does caulking go?
I also see NO evidence of any caulking between the metal frame of the door and the plastic trim that runs along the bottom of the Tab.
Your arrows and suggestions were much better than Nucamps, but again, where exactly are we supposed to check for cracks in the caulking if there is none there to being with?
If any of the moderators that are in touch with Nucamp are reading this, can we please ask them to provide GOOD pictures of exactly where we are supposed to caulk? This would include them taking pictures with the wheel well trim taken off and show exactly where we are supposed to caulk. This is one thing that I do find unacceptable for the caliber of manufacturer that is Nucamp.
Of if anyone else has pics of where the caulking is supposed to go, can you please post clear pictures of the caulking?
Would be greatly appreciated. Thank you
It took some doing but I found that 2016 posting. There was a lot of discussion on the caulk to be used and I'm not promoting one over the other.
https://tab-rv.vanillacommunity.com/discussion/comment/40879#Comment_40879
@lkc001, it is interesting that you found no caulking where the fender attaches to the sidewall, or under the door frame. Another reason why it would be very helpful if nüCamp could update their maintenance bulletin with very specific and updated information. Maybe they have found no need to caulk those areas, or maybe there has been some modification made to those areas since 2016, although I doubt it. However, if they did make a relevant design change, it would be greatly appreciated if they would share that info.
I do agree with you wholeheartedly that removing the fender screws multiple times is likely to result in them becoming ineffective. It is already a common problem that the screws throughout the exterior of the trailer become loose and need to be checked regularly.
In response to your specific question about where to caulk if there is no caulk present to begin with, I would say that you should only need to caulk places where you can see cracked or obviously missing sealant. However, if you can see light coming through an opening that is obviously exposed to the elements (i.e., rain, snow, dust, etc.) and is likely to eventually cause damage to the interior of your camper, caulk those as well. Use a polyurethane based caulk, because silicone will not adhere properly to the fiberglass/Azdel exterior of the trailer. I have noticed an exposed area around the cutout for the outside 110v plug where light and air is clearly penetrating through the sidewall of the camper, so I have been intending to use some spray foam to seal that off, because the gap is too wide for sealing with caulk.
I await (along with you) nüCamp's input.
Until I can get some more info and pics I don't think I am going to be removing the screws on the fender trim every year. I just think that is a recipe for stripping out those screw holes permanently.
Thank you for the tip about the exposed area around the outside 110v plug--I will look at that. My plan is to get on the ground again on my back and look for more areas where I would be able to clearly see caulking and reapply as needed.
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
3M Marine Adhesive Sealant 4000 UV, PN06580, White
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
https://tab-rv.vanillacommunity.com/discussion/2895/attention-special-factory-maintenance-notice/p1
I had been searching for it, because I remembered it had @SweetlyHome's excellent contribution of photos with the fender removed. It looks like it would be impossible to inspect & caulk those wheel well joints on the side without removing the fenders.
Wondering if there is also a black version of the 3M 4200 adhesive sealant for the underside.
Geocell Proflex Stays elastic and stops leaks quickly. Bonds to virtually all RV materials and adheres to damp, frozen and oily surfaces. Withstands joint movement and temperature change due to RV travel. 25 year life expectancy. 10 oz.
Saw it posted on a FB page
Tampa FL
