Easy Leveling of the 400
System
Administrator Posts: 188
This discussion was created from comments split from: Extending Stabilizer Reach.
Not sure if this is the right place for my question, but I did a discussion search of "automatic" leveling and the only place it brought me is here.
I have seen Dalehelman's wonderful scissor jack leveling mod for the 320s, but nothing along those lines for the 400. I have a 400 BD, am solo, and would love an easier method of side-to-side level. Has anyone done an "automatic" level or put scissor jacks on a 400 BD or seen a thread on those topics please?
Although I have mainly stayed at campgrounds, I find that either the spots are consistently terribly "unlevel", or my ability to locate and succesfully back into a level portion of the site is severly lacking. I have an Andersen which (most of the time) works great. Being solo it does require much in-and-out of the vehicle, and sometimes 4" of lift just isn't enough. Yes, I *could* carry many more blocks but I'd rather find a cleaner solution. With properly sized "scissor" levelers, I wouldn't need to carry anything extra. No muddy, sandy blocks to store.
You can probably tell from my questions, I'm no pro, but I am willing to research, ask questions, and experiment to a certain degree.
2020 T@B 400 BD w/Solar, Microwave and Closet
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab -
@Amazonica, the points at which these retrofitted scissor jacks are attached are not necessarily designed to support the weight of the trailer.That said, Dalehelman and several others have used them on their 320s for several years without apparent damage. However, the 400 is a considerably heavier trailer so whether or not they would work in that application remains to be seen. I personally wouldn't do it, but I do respect those pioneers who are willing to test such things out on their own equipment. ;-)
That makes sense ScottG, thank you. I don't want to ruin anything. More research is in order.
Sounds good, @Amazonica.I'm going to kick your question out to its own discussion in case others have additional insights to offer.2015 T@B Max S (320)
ok, thank you.2020 T@B 400 BD w/Solar, Microwave and Closet
I would continue with Anderson and add a LevelMatePRO Bluetooth wireless level sensor or similar. That reduces the in and out and makes getting level easier. Of course over 4" of level is still an issue, but jacking the entire trailer off the ground is probably not good either.
Honestly most parks I have seen out west where I live 4" of lift is plenty adequate that the Anderson provides.2019 T@B 400 Boondock Lite -
Thank you @N7SHG_Ham. You are correct, most of the time 4" is sufficent to level. I think I'm getting "mod happy".
"Mod happy" is now recognized in all camper forums as a symptom.On my first few trips with the trailer I was awful at finding a level spot. More and more, though, I manage to get the trailer in a spot where no extra leveling is really needed. It just takes a bit of practice.
Towed by 2014 Touareg TDi -
I wholeheartedly second this. I use the Anderson and the LevelMatePRO and leveling is a breeze, provided you need <4” side to side. Adding the LevelMatePRO remains one of my favorite upgrades.N7SHG_Ham said:I would continue with Anderson and add a LevelMatePRO Bluetooth wireless level sensor or similar. That reduces the in and out and makes getting level easier. Of course over 4" of level is still an issue, but jacking the entire trailer off the ground is probably not good either.
Honestly most parks I have seen out west where I live 4" of lift is plenty adequate that the Anderson provides.Alan & Natalie McKinney, TX
nüCamp: 2019 T@B 400 Boondock Lite
Dream big... work hard... never give up. -
For those not yet ready to spend the $140 for LevelMate Pro, there’s a cheaper app that may get you by for now. I‘ve tested one on iOS called Caravan Level Remote. Does require two devices; I use an iPad and iPhone, sticking one on the floor of the trailer as the sensor. I naturally haven’t had to actually use it since I bought it (doesn’t it always work that way?), but it tests fine in my driveway.
Don’t know if there’s an Android equivalent, but I expect there is.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW -
Thank you all. I'm going to have to check out the LevelMatePRO, and the Caravan Level Remote app. I have an iPad, but an Android phone. This is all great info! I never knew these options were out there.
I did see this warning on my current Stabilizers when I was under there checking them out. "Do not use jacks to lift tires off ground". I'm not saying others are wrong, just that this is what mine say.
Yes, your stabilizers are strictly for keeping the trailer from rocking while parked. They are not for leveling.Amazonica said:
I did see this warning on my current Stabilizers when I was under there checking them out. "Do not use jacks to lift tires off ground". I'm not saying others are wrong, just that this is what mine say.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW -
I use the BAL leveler to level my 400, but I'm usually in pretty decently level spots that only require about 2-3 inches to level. I'm a solo average-sized female with arm flab instead of muscle and I do just fine. My plan in the event I get a really unlevel spot and I cant crank it any higher....I have a small bottle jack that I can set up at the jacking point behind the tire for a little bit of lift assistance. You might also need a block to sit the jack on.
Thank you for the tips @TabbyShack. Sounds like you could have been describing me. ^^😁2020 T@B 400 BD w/Solar, Microwave and Closet
We have been using the $34 Witmotion device for leveling, as the Android equivalent, along with the free "Remote Level" Android app for bluetooth connection, as shown & described in the link below..
(I also left a review on Amazon at the link given.)
https://tab-rv.vanillacommunity.com/discussion/6328/leveling/p2
We've been using it for a year now, and find it's the best available alternative for us. I only wish it had a stronger bluetooth connection like those in the Victron battery monitor & solar controller. Sometimes when using it from the drivers seat, we may lose the connection; but for adjusting the tongue jack or rear L/R leveling jacks, for example, no problems with the sensor mounted under the front cabinets.
Very cool solution @BrianZ. I do have an Android phone.
I like your "charging station" in your post photos too. Very creative and practical - thanks!
I can't tell you how much easier it is to find that level spot in a campsite when you have the Levelmate Pro. It has saved me a ton of time and aggravation. I especially live this when I am overnight parking and not unhooking from the TV.
Thank you @jkjenn. It's good to hear real-life opinions from people with similar set-ups.
Pulling a t@b 400 bdl and we use the Levelmate Pro and the Anderson level system. I also started using an Iphone app "Bubble Level". When I think everything is level, I open my camper door and set my iphone on the door sill with the app open. If I'm level, I hear a beep. I then go to the front and hold the phone just under the front window. Now, I'm sure there is an error level, but thus far the Levelmate and the app have been consistent. To be honest, I got the app because my wife always questions the Levelmate with her "calibrated eye" and the app just reinforces the accuracy of the Levelmate and I get to say "I told you so".
2025 Haven 2202020 Ford F-150 XLT (V-8)Niceville, Florida -
LevelMate Pro is on my buy list for someday. Already have the Anderson levelers and that is a quick way, even without the LevelMate pro.
One thing to note is when calibrating any of these devices including a phone app, is what do you want level? The fridge, the shower floor, the counter, the floor? They all are NOT level at same time. So level what you want to with a an actual level the 1st round and then calibrate the level mate pro to show level.2019 T@B 400 Boondock Lite -
$2.95 at Home Depot...just sayin...
San Diego, CA
www.airbossone.com
https://fineartamerica.com/profiles/owen-ashurst/shop -
2021 T@b 400 BD "Vixen Gail"
Leadville Colorado -
bergger said:....
I like the K.I.S.S. principalMe too! ;-)
(Seriously, I do like the looks of those Lego-thingies. Gotta add those to the collection some time.)2015 T@B Max S (320)
Going to fall on the proverbial sword here and cop to rookie'ism on two fronts.
First, when browsing up and down the aisles in Camping World before picking up the rig, among the two shopping carts of stuff I walked out with were these:
They work fine...but a bit pricey. Could have gone with a cheaper version but so be it. Guess I saved money on the level itself from Home Depot!
Second point. See those triangular-shaped blocks under the curved red levelers. Those are wheel chocks. Turns out, they're also used to chock the wheels so when you unhitch the TV, the rig doesn't roll backwards towards the ravine!
Yeah, I did that. Just as the hitch was about to release from the TV, it crossed my not so giant brain that I didn't have the wheels chocked. Sure enough, gravity proved true to form...the rig slipped off the blocks I had under the footpad and started to roll backwards towards oblivion.
If there's a video out there, you'll be reminded of Wile E. Coyote. I'm holding onto the jackstand for dear life, squated down almost horizontally, dust flying from under my US Keds as I try to overcome Sir Isaac Newton's most ingeneous discovery. Fortunately, the wheels found a small rise in the ground after about a foot or so. No harm...no foul. Whew...
Sometimes it's the most heartpounding and difficult lessons we learn that stick with us...forever.
Bottom line: if you're reading this as someone who's relatively new to RV'ing...don't be me!2020 T@B 400 "OTTO" (build date 08/19)
San Diego, CA
www.airbossone.com
Blueespy said:Pulling a t@b 400 bdl and we use the Levelmate Pro and the Anderson level system. I also started using an Iphone app "Bubble Level". When I think everything is level, I open my camper door and set my iphone on the door sill with the app open. If I'm level, I hear a beep. I then go to the front and hold the phone just under the front window. Now, I'm sure there is an error level, but thus far the Levelmate and the app have been consistent. To be honest, I got the app because my wife always questions the Levelmate with her "calibrated eye" and the app just reinforces the accuracy of the Levelmate and I get to say "I told you so".Exactly what I use (except for the I-Phone and App), couldn't be simpler! Had the TAB in my yard, used my 4 foot level for side to side, then set it on the floor for front to back. Set that as my "level positions" in the Levelmate Pro and done.Best Regards,Brad2020 400 BDL aka "Boonie"
Concord, NC
- 916 Introductions
- 72 Teardrop Groups & Links
