Greetings~
We recently bought a 2010 T@b TQ, and we live in SW Wisconsin. Over the last couple months I have been going over all the systems to make sure everything is ready for Spring. When I first tested the furnace and the cooktop they worked great, just a month or so ago. Now neither one will work. My tank was registering in the yellow zone, but it would run other appliances so I assumed it was ok, but just to be sure I bought a new full tank. Still nothing. I have read that occasionally tanks can have moisture in them that can cause a line or a regulator to freeze up. It has been mighty cold here. I pulled the trailer out of storage and put it in the sun yesterday where it was 45-50. Still nothing. I can pull it into a heated shop space which I may do, but somehow I'm guessing it's something else. Bad regulator? Any advice please?
Thanks,
Peter.
(Edited to add SOLVED To title to help with searching — Verna T@B Admin)
2010 T16-Q & 2013 Toyota Sienna Limited AWD.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
This line in our tab looks fine, it looks new.
Tampa FL
If an add on gauge is showing pressure, then the check valve in the tank is not closed.
When you open the stove valve(s), does the pressure stay in the green? If yes, It is not a problem with the tank delivering fuel. BTW - You do know the stove valves have to be turned on, pushed in and held in until the thermocouple gets hot?
I had an OPD valve stick closed on a full spare tank. After removing the tank from the tub and jostling it around a bit, it began working.
It does take a while for air to clear from the lines after a tank change. I may take a full minute or two for gas to reach the stove burners. The furnace may need to be reset after failing to start. It will have a red flashing light on the control circuit board under the front cover and a small push button for "reset".
It really seems you have tried all the common fixes. I'm just following along to see a resolution.
Good luck,
Bob
I'm sorry but it was a long time ago and I can't tell you exactly what to look for.
Maybe this manual will help: http://bryantrv.com/docs2/docs/hflamefurn04.pdf
But if the stove isn't working either then I doubt that this will be your solution.
https://www.etrailer.com/Propane/MB-Sturgis/100575-12-MBS.html
That is what caused my stove not to work. Once I replaced that hose, all worked again.
MOUSE-KE-T@B
Harvest, AL
In addition to clogging, that hose also has propensity for leaking. I had to replace mine last season. Good thing to keep an eye on when doing routine inspections and maintenance.
MOUSE-KE-T@B
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
https://tab-rv.vanillacommunity.com/discussion/comment/139214#Comment_139214
